Old 07-07-2018, 10:40 PM
jwize101 jwize101 is offline
Default Panther Y travel question
Hello all,
I am in the process of putting T-Tracks in my spoil board. I have a panther 508. My question is what is the max Y travel? I had to clear my blue boxes with G49 for a part of my table and when I was manually surfacing the table I was starting to cut the black on the back of the table that is farther than normal. I went and looked and didn't see any limit switches on the back of the gantry. My current position on the table for Y is 101 and did not know if I could cut more or am I already to far for the machine.
Thanks for the help,
Jason
Old 07-08-2018, 08:05 AM
de5 de5 is offline
Jog it slowly while looking at the bearings and stop it just before they hit the frame. That's your max travel.
Charlie Hind
Cobra 404 ATC with 12 tool positions & 4th Axis (2012-present)
(2006-2012 - K2 CNC... sold in 2012 to buy the Cobra)
www.hindocarina.com
http://facebook.com/hindocarina
Old 07-08-2018, 10:20 AM
You can get the exact set limits for your machine merely by looking at your WinCNC.INI file. :) I did that when I was working on my own spoil board setup so I could surface things out as far as possible without tripping the limits. It was more than an inch beyond the "published" table length, as a matter of fact.
You may actually need to temporarily adjust your Z-limit if you'll be cutting directly into your factory table for the tee tracks as Camaster has things setup so that you're less prone to damaging your table beyond a short plunge. Very short.
Old 07-08-2018, 11:49 AM
Thanks for your response. Jim, where can I find the WinCNC.INI file? Sorry for the newbie question.
Old 07-08-2018, 12:53 PM
UglySign UglySign is offline
C:\WinCNC\wincnc.ini
Old 07-08-2018, 01:46 PM
Awesome!!! Thank you!
