Old 05-02-2012, 01:27 PM
gj87 gj87 is offline
Stinger Owner
Default Shelf Pin Holes
When doing shelf pin holes on the cnc, what type of router bit do you use? Upcut, downcut, or regular endmill. I thought that I read somewhere that a downcut endmill could cause a fire.
Gerald
Old 05-02-2012, 01:30 PM
up spiral 5mm or .25 inch (just make sure your pins match the hole)
Old 05-03-2012, 06:19 PM
Stinger Owner
Thanks James, will have more questions in the future. Machine is couple weeks away.
Gerald
Old 05-03-2012, 10:28 PM
Eric Mims Eric Mims is offline
I've used a compression bit with success, but made sure to peck drill. If you try a downspiral without peck drilling, be sure to be nearby with a fire extinguisher.
Old 02-28-2014, 07:16 PM
Timberwolf Design Timberwolf Design is offline
I use a .250 end mill One single down cut to depth and your pins will fit perfect
