Old 03-17-2014, 04:49 PM
Patrick
Guest
Posts: n/a
Default Tooling for cabinets
I am thinking 3/8" down cut end mill for dados,
Do I want to use a FEM or a normal end mill.
Also thinking of 5mm compression bit for shelf pin holes and cut out.
Any thoughts? My main question is really about using a FEM or not for the dados.
Old 03-17-2014, 04:57 PM
I like the downcut endmill for dados, because it gives a clean top edge. There are dado compression bits that have a very short upcut portion at the end - I've heard these are better for dados, but I've never tried them. Normal compression bits don't work well because the upcut portion is too long.
I like 3/8" compression bits for cutting out parts.
The 5mm compression is not the best bit for drilling shelf holes. The upcut portion will give tearout as it starts, and the chips won't clear once the downcut portion enters the hole. I would use 5mm boring bits (or even regular 5mm brad point drill bits). When I drill, I slow the rpm down (for 3/8" I use 3600rpm and I might go up to 5000rpm for 5mm).
Old 03-17-2014, 05:23 PM
Patrick...
Russell is right on. Use a down spiral or mortise compression for dados. Use a drill for drilling. I suggest you use a 3/8" compression or mortise compression for perimeter cutting. The 5mm compression reduces speed way beyond it value due to how slow it must be run.
Control & ATC Retrofits
Old 03-17-2014, 06:36 PM
eandico eandico is offline
I used a 5mm compression on my first cnc.
It did not have tool change and it was quicker to use the same tool for all holes dados and cut out. That is what they were designed for.
Best,
Nick
www.theeandicompany.com
