Old 12-17-2014, 02:29 PM
dustboy dustboy is offline
Default Tips for through-drilling melamine?
I've started cutting melamine closet parts for a local installer. When I through-drill my 5mm holes (for dividers, etc) I get some chip-out and even a little bulge on the back side.
I'm using a brand-new 5mm brad point bit from US Router Tools (with the 1/4" shank for the PC router). It runs at the minimum (~12,000) RPM at 60 vertical IPM. It cuts about .01" into the spoil board. A clean spoil board helps but we're still getting more chip than we want (i.e., more than none).
Near West Cabinets
Evan Andersen
Stinger III X3
15 HP FPZ Regen Vacuum
Old 12-17-2014, 02:32 PM
Why thru drill the shelf holes, is he using a single sheet or component construction,, we drill 5mm 12.5 deep (1/2")
Old 12-17-2014, 02:52 PM
These are closet verticals. On left and right verticals we half-drill, but center verticals have two sides. I don't want to get into 2-sided operations.
Near West Cabinets
Evan Andersen
Stinger III X3
Old 12-17-2014, 02:57 PM
then you need a 5mm 2x2 compression bit. if there is such a thing
Old 12-17-2014, 06:26 PM
eandico eandico is offline
I have gotten 5mm 2+2 compression tools from Centurion tools in the past.
They have a .25 shank.
I used them a lot with my old cnc because it wasn't ATC.
I could drill shelf pins cut dados and cut out cab boxes with no tool change.
Best,
Nick
www.theeandicompany.com
Old 12-17-2014, 06:29 PM
machineitright machineitright is offline
dustboy,
Try reducing the feed rate by half for the last .060 of the depth and see if this helps.
Donnie Horton
machineitright@hotmail.com
Stinger II SR-44
Recoil ready
FTC, Laser Cross Hair, NEMA 34 900 oz motors
3 KW HSD spindle
Spindle speed control
VCP+Cut3D+PVC
Old 12-18-2014, 11:11 AM
I think Donnie has it right, I was reluctant to reduce the feed because this bit has to drill thousands of holes in its lifetime. My first bit lasted a year and it was still going when I replaced it.
If the last little bit is slow it shouldn't heat up too much. Is there a way to do this in Vcarve without adding a second toolpath?
Near West Cabinets
Evan Andersen
Stinger III X3
Old 12-18-2014, 01:12 PM
Scott12 Scott12 is offline
I do that all the time with a 5 mm V point bit. No blow out on the back side.
Scott Williams
Cabinet Solutions
CAMaster Cobra 510 ATC
State College, PA
Old 12-18-2014, 03:58 PM
Have you found one that will fit a Porter Cable collet?
Near West Cabinets
Evan Andersen
Stinger III X3
Old 12-19-2014, 04:03 PM
Haven't really looked as mine goes in my spindle.
Scott Williams
Cabinet Solutions
State College, PA
