Go Back   CAMheads CNC Router Forum By: CAMaster CNC > The Water Cooler > Friends Of the CAMheads
Old 01-30-2014, 01:32 PM
Default Black Box Vac
I wanted to start a thread on the Black Box Vacuum Systems.
www.usroutertools.com
Old 01-30-2014, 01:45 PM
The new 2014 Black Box Units have a integrated cooling fan as well as a adjustable relief valve to help protect the motors.
The valve will allow the motors to pull air from another chamber from inside the box. This will help keep down any noise from the valve.
The electric fan also helps with the over all noise of the unit by eliminating the top vent that was directly above the motors.
This change is on all three Black Box Units.
Old 01-30-2014, 01:49 PM
Michael Mezalick's Avatar
CAMaster Owner, (MOD, KOTR)
What do they cost ?
What else is needed to complete a Vacuum top ( and cost )?
I'm looking at changing to a vacuum top for my 408 X3
~M
Michael Mezalick
Cobra, WINCNC
3-D Modeling
https://carveddetails.com
mm@mezalick.com
Old 01-30-2014, 01:50 PM
Damn,,in the first picture it looks like the box is as big as the truck on the left..
~M
Michael Mezalick
Cobra, WINCNC
3-D Modeling
mm@mezalick.com
Old 01-30-2014, 03:49 PM
Michael, I just used 2" Schedule 40 PVC pipe to make up the plumbing under the table. I cut a plenum into the MDF top, with a hole cut through for the pipe to come up into (I made sure the holes lined up with the holes precut in the frame under the table, so I just had to run the PVC pipe straight across and out the back).
I'm really interested in that Black Box vac. Do you have a flow/pressure chart for it? (what would the pressure be at say 200cfms?)
Old 01-30-2014, 04:01 PM
Brian O Brian O is offline
Is it possible to retro fit the fan and valve to mine?
Brian O
stinger III x3
vcarve pro
Old 01-30-2014, 05:36 PM
Jimwill52 Jimwill52 is offline
Will you have one at McGrew's Aspire Camp?
"If it was easy anyone could do it!"
Jim Williams, CaMaster Stinger w/recoil, FTC
http://expressionsofhonor.com
Old 01-30-2014, 06:06 PM
That's one sweet looking black box Joey ........ is that one mine. I am in the design stage of creating a vacuum top. I want a 1" phenolic top (no swelling) and pop-up pins to a line my sheet good, that the reason I bought a 5x8 machine. I will only be cutting a 4x8 vacuum plenum. So once I get all the parts in house I will be modifying my machine.
Old 01-31-2014, 02:07 PM
darde darde is offline
If my CNC crashes will the black box have to be sent away to be inspected to find out what went wrong.
Old 02-03-2014, 06:15 PM
Yes Mick That is yours.
