Old 05-31-2018, 11:29 AM
StrategyMarine StrategyMarine is offline
Default how would I cut a 1/8" t-slot
I just received my Panther and I'm having a blast learning how to use it. Thanks to everyone this Forum has saved me a lot of headaches already!!!
I have a glovebox/door I want to design and cut for my boat. It is going to need a t-slot/dovetail channel cut in it so I can attach an seal for the door. I'm cutting out of a marine plastic(Starboard) that cuts easy but I'm having trouble finding out away to cut the slot. I have some t slot bulb seal that I want to insert in the channel to seal the door when I close it. I have attached a few picture so you can get an Idea of what I'm trying to do.
Top of channel 1/8"
Bottom of channel 3/16"
depth of channel 3/16"
I have a door that I'm trying to copy and I have attached a picture of the channel I'm trying to copy. Looks like i could make a pass with a 1/8" endmill then make a second pass with some kind of dovetail bit to make the bottom of the channel but I have had a hard time finding a bit small enough that will work. Any suggestions?
Panther 4x8 w/Performance Package
3kw Spindle
Hurricane Vac
Vcarve Pro 9.0
Old 05-31-2018, 02:35 PM
Erik Land Erik Land is offline
I buy from RedLine once in a while, they have a couple 3/16 dovetail cutters.
https://www.redlinetools.com/CatSear...-cutters#21981
Erik
Erik Land
Dorena Oregon
Cnccutter@gmail.com
Stinger I SR24 11/27/17
Performance package Pro:
2" Gantry Lift
FTC Fast Tool Change
Laser Cross Hair
Counter Balance
Tee Track Table
Kent Dust Shoe
Aspire 9.5
Rhino
Old 05-31-2018, 02:41 PM
TimPa TimPa is offline
a keyhole router bit may work. there are several sizes... will have to check your dimension needs.
Old 05-31-2018, 06:20 PM
UglySign UglySign is offline
Would MicroCut work?
http://www.microcutusa.com/dovetail.php
Old 05-31-2018, 08:30 PM
Originally Posted by UglySign View Post
Thanks for the tip on a cool site! No pun intended......
Old 06-01-2018, 01:20 PM
Both of sites look like great resources. I think I should be able to find something on one of those sites that will work.
Thanks for the help, what a great resource!
3kw Spindle
Hurricane Vac
Vcarve Pro 9.0
Old 06-01-2018, 02:56 PM
SCHEPEBC SCHEPEBC is offline
I can't remember who to give credit for but someone on here said to run a regular upcut bit thru your path first at the correct depth and then come back in with a dovetail bit to help take some of the cutting/loading off the dovetail bit. I tried it and worked great!
