Old 06-22-2018, 03:34 PM
Default Tool Change Prompts (with FTC)
I'm truly loving have the FTC active and working on my SR-44...even though the time to change a tool and measure is about the same as "manual measurement" it's a lot less tedious and it's also nice having a smaller number of cutting files for a given project.
One thing that's kinda strange to me, however, is that WinCNC doesn't prompt for the tool in what I consider a logical way. There's no message that says "change too" or "which tool". Only a "remove dust boot and press enter". Michael from Camaster indicates this is normal behavior.
Has anyone come up with a way that actually uses the tool information from the TAP files to prompt for both the change and the correct tool? It seems to me that would help reduce human errors. As it is, it means one must memorize the toolpath order and tools required for each change without such helpful prompting.
Thoughts? Solutions? Recommendations for a great bottle of wine to overcome this angst?
Old 06-22-2018, 05:11 PM
Jim,
I have some great recommendations for a bottle of wine but not the WIN fix you seek.....lol
2018 Cobra Elite 5 x 10 ATC
"You never learn anything by doing it right."
If that were true, I would be one of the most intelligent people you would ever meet.
Old 06-22-2018, 05:49 PM
Jim...
You sat in the front row….
Remember the "Organize multiple bits" on the CNC checklist?
Now do you know why it was there?
I have messed with this in the past. The problem is that the toolname variable cannot be passed thru to the FTC macro. The Vectric toolname is listed on the line before or after the "T" tool call, but you would have to scroll up a few lines in the code viewer to see it.
Old 06-22-2018, 06:25 PM
Like Gary says, you just hit the scroll up for the text window where you see the WinCNC commands.
Old 06-22-2018, 06:31 PM
Bruce Page Bruce Page is online now
I don’t use the FTC as often as I should, especially if it is only a 1 or 2 cutter job. If it requires multiple cutters and the FTC I use this simple organizer.
Bruce Page
Stinger 1 SR23
Mick Martin Table
Aspire 8.5, WinCNC
Chips-a-flyin’
brucep128@gmail.com
Old 06-22-2018, 07:10 PM
Here's one of mine
Old 06-22-2018, 07:24 PM
Jim...
Yea, I know...I'm peeing on rainbows here. :) I guess I expect too much logic from, um...computers. LOL
I'll have to get to cutting that top-of-controller tool holder sooner, rather than later, since that's pretty much the best way to handle this to insure no mistakes are made.
Old 06-22-2018, 08:03 PM
eph210 eph210 is offline
When I first started with WinCNC I had to scroll up a few lines at a tool change in order to see the tool call out. After using WinCNC for a while I learnt that I could re-configure the screen to be able to display more of the code. If the code box is expanded to show at least 12 lines, the tool call out is visible.
The WinCNC display is very adaptable but it is not drag and drop. I have changed the display a number of times as I have added various items to it.
Before you make any changes, make a copy of the entire WinCNC folder and store it somewhere safe.
Here is a thread with more information:
http://www.camheads.org/showthread.p...=wincnc+screen
Euan Hanchard
Serrano Studios
Stinger I FTC
Wincnc vcarvepro
Old 06-22-2018, 08:43 PM
Very nice, Bruce! I see a quickie project for me.
Old 06-23-2018, 11:50 AM
Why not edit the post to put it on the same line? Or will WinCNC not allow that?
