Old 06-26-2018, 11:53 AM
kjoiner kjoiner is offline
Default Marking bend lines on sheet metal parts
I make a lot of sheet metal parts that are subsequently bent. I can generate flat patterns with bend lines in my CAD system. I bring all of that into V Carve and cut the flat patterns, but I mark the bend lines afterward with Dykem and a height gauge. It's slow and I have to clean off the Dykem afterward.
I'm thinking of using either a marker holder like Cosmos has or using a diamond drag to mark the bend line. I want the bend line as fine as possible.
I noticed on Cosmo's site that the Z required for the fine tip marker is 5.6" which is probably too high for my Stinger 1.
Any thoughts?
Kyle
Kyle Joiner
IPA LLC
www.thinkipa.com
Duluth, GA
CAMaster Stinger 1 23
Vectric V Carve Pro
Solid Edge ST10
Old 06-26-2018, 12:33 PM
WRAWL WRAWL is offline
Have you tried using a ball nose endmill to make a very light cut to identify your bend lines? Im not sure if that would affect your finished product or not but it would definitely work.
Old 06-26-2018, 02:45 PM
I have a tapered ball end mill with a 1/32 radius, but I want to keep the line as sharp as possible.
Kyle
Kyle Joiner
IPA LLC
www.thinkipa.com
Duluth, GA
Vectric V Carve Pro
Solid Edge ST10
Old 06-26-2018, 02:55 PM
SCHEPEBC SCHEPEBC is offline
I have used an engraving bit. Works well
Old 06-26-2018, 07:11 PM
I think a diamond drag engraving bit is going to get you the thinnest line possible. Just my humble opinion.
Use a diamond drag or sharpen a broken carbide or HSS tool to a point. You can do this on a bench grinder or 4.5" grinder with flap sandpaper disc etc.
Old 06-29-2018, 08:37 AM
I did some testing yesterday while making another batch of brackets. I did one test using an In Groove cutter I have. It worked pretty well, but I think the tip chipped a little during the test. For the second test, I used a 90 In Tech v groove cutter. It worked pretty well but I think a diamond drag might be the best option.
Even though each test did not produce perfect results, I was able to elminate the time consuming steps of applying Dykem, scribing the bend lines and then having to remove the Dykem afterward. That is a significant time savings.
I've got a lathe at work and I can make my own diamond drag tool. The only unknown for me at this point is how much spring pressure is needed. I see that some tools like the Widgetworks has two springs. Does anyone have information on how much force is typically required?
Thanks!
Kyle
Kyle Joiner
IPA LLC
www.thinkipa.com
Duluth, GA
Vectric V Carve Pro
Solid Edge ST10
Old 06-29-2018, 10:45 AM
$25 with diamond drag bit, spring & set screw---> Ebay
Old 06-30-2018, 08:33 AM
I don't know exactly what you make, but sometimes it can be faster to just make a jig or use a tape and pencil to make mark.
V Carve 9, Mozaik
Old 07-02-2018, 08:52 AM
Hi JP,
In the most recent case, I was making 55 small brackets. Applying layout blue, scribing the bend line and later cleaning off the layout blue takes a lot of time and is messy. Having the Stinger mark the lines is much more efficient.
Most of the parts I make are prototypes, but in this case, I needed to make the brackets because our supplier was running late and that could hold up production on our end.
Kyle
Kyle Joiner
IPA LLC
www.thinkipa.com
Duluth, GA
Vectric V Carve Pro
Solid Edge ST10
