Old 07-02-2018, 09:38 AM
Cleaning Dykem from 50+ parts would be a headache. The diamond drag will give you a line similar to marking with the height gage minus the dykem. Am I correct in assuming you are using a box and pan/finger brake? If you had a hydraulic press brake with a backstop you would not need to mark the parts before bending them. I never got very good with a finger brake, I have seen some guys that were pretty impressive with it, but never on par with a good Amada/LVD.
-PETE
SR-34
V-Carve Pro V8
Recoil Ready
Old 07-16-2018, 10:24 AM
kjoiner kjoiner is offline
Hi Pete,
I use either a finger brake for larger parts or a small vice brake for small parts like the brackets I recently made. The vice brake is actually quite handy
http://www.grizzly.com/search?q=(vis...(vise+OR+brake)
Kyle Joiner
IPA LLC
www.thinkipa.com
Duluth, GA
CAMaster Stinger 1 23
Vectric V Carve Pro
Solid Edge ST10
