Old 06-29-2018, 10:13 AM
Eb0la11 Eb0la11 is offline
Default CNC Lathe Work Needed near Atlanta
Looking for a fellow camhead to make this part in a qty of 12. I can supply the wood. Please message me if near Atlanta and can get it done. It is just the walnut that would need to fit inside the tube. I can supply the wood and a small piece of the tube to test fit. Message me with pricing and we can coordinate. Thank you.
Old 07-02-2018, 09:46 AM
Is there a better place to post this? I could ship the wood somewhere else if needed. Looking to get this done over next 10 days. Can ship today. Advise.
Old 07-02-2018, 10:00 AM
If I'm reading the PDF correctly, that's really better suited to a normal lathe, not a Recoil on a CNC. Any local turner should be able to, um...turn...those out for you relatively quickly. Like in a few hours including setup time. You might check on sawmillcreek.org in the turning forum to see if there is someone very local to you since that would eliminate shipping costs in both directly.
