Go Back   CAMheads CNC Router Forum By: CAMaster CNC > CAMaster Machines > Stinger Series CNC Routers > Stinger I (Table Top)
Old 12-04-2017, 10:43 AM
jdonaldson jdonaldson is offline
Default Help reset estop c1 error
Hopefully someone can point me in the right direction. After finishing two
jobs I shut the vacuum and pc down but not sure about the machine control box. Later that evening I was in the shop and evidently hit the estop while moving some stuff again I don't know if the machine was still on or not. Lesson learned will not get in a hurry and pay attention to my shutdown procedure. Went back next day to run another job and now I get Reset Estop C1 and it also says running Macros/macro-abort.mac and the machine
is dead.
John
John
Stinger SR23, 1.7KW
Storm Vacuum, performance
package, Epilog Helix
Aspire 8.5, coral draw 7
Old 12-04-2017, 10:55 AM
Be sure to turn the e stop button when resetting. The turn releases the off switch.
If you have the control panel open, the door switch might have it off too. I don't know if you have that feature so just guessing.
Old 12-04-2017, 10:57 AM
Erik Land Erik Land is offline
If you hit the e-stop and pushed it in, did you rotate it and get it to pop back out to disengage?
Erik
Erik Land
Dorena Oregon
Cnccutter@gmail.com
Stinger I SR24 11/27/17
Performance package Pro:
2" Gantry Lift
FTC Fast Tool Change
Laser Cross Hair
Counter Balance
Tee Track Table
Kent Dust Shoe
Rhino
Old 12-04-2017, 12:15 PM
Thanks for the quick reply's, I have pushed in and reset the switch several times and it seems to pop out when I rotate it. I haven't taken the cover off
to check and see if any things loose.
John
Stinger SR23, 1.7KW
Old 12-04-2017, 02:14 PM
There are led's on the power supplies and on the drive unit it self, what colors are they? Solid or blinking?
Old 12-04-2017, 03:36 PM
Gary,
I will pull the cover off this evening and check. Can you give me a next step depending on whether I have no/blinking/solid led
John
Stinger SR23, 1.7KW
Old 12-04-2017, 05:19 PM
The next step is dependent on the condition displayed by the LED'S
Old 12-05-2017, 12:27 PM
Thanks again for all the quick responses, I've run an electric motor repair shop for the last 40+ years and if I had a dollar for every time I told someone it sounded like a voltage issue and before you pull and bring the motor in make sure your getting the correct voltage. We'll I'm sure you guessed it after pulling the cover and seeing no lights started checking and then realized the 110plug had come loose, I had checked the 230.
Oh well this little scare will make me more systematic in my startup / shutdown procedure
Thanks again
John
Stinger SR23, 1.7KW
