Old 11-17-2017, 03:20 AM
Steve Lynch Steve Lynch is offline
Send a message via Skype™ to Steve Lynch
Default I made me a nice Magnetic Dust Boot (Files Attached)
I was being driven crazy by the unimaginitive Black Dust booth that came with my New Panther. I saw a lot of $150 magnetic boots online, but I decided to just make one myself.
I wanted a smaller one that would fit my machine, and minimize left hand table suction loss.
So I made this one:(below)
I used 1/2" acrylic, and got the rest of the stuff from Mcmastercarr.com
4" to 3" vacuum reducer part # 2221K32
Brush Strip part # 7900T5
rare earth Magnets with countersink #4 screw hole part # 5862K14
The countersink magnets are one polarity, so a second set will not stick to them and be able to be screwed in. i designed mine with 1/4" magnets on the opposite side, but they didn't work like I planned, so i just used a washer, which worked fine, but I'm going to make a second layer, and pocket 1/2" magnets in the next one, and sandwich the two.. this will also make up for the 1/2"-ish gap between the bottom of the bit and the bottom of the brush.
the brush is pressed into the pocket, then I ran a bead of hot melt glue.. It works perfectly!
one of my reasons for using washers was also that It makes a small air passage between the 2 pieces.. this increases the air flow which allows faster air flow which picks up more chips.
I attached the design files.. if anyone wants them, you can make your own mods, or just cut one out.. i just thought I'd share. Not like everyone here can't make one, but hey! I already did the work, so i figured I'd share. you'll have to make a couple small changes for your machine probably, but you can easily re-size the whole thing for any router or spindle.
enjoy!
Brandy New Panther PT-408 8" Gantry
Phenolic Top, Servos, Counter Balance, 4 H.P. Spindle, Laser, Hurricane Vacuum, And FTC.
Win CNC 3.0, & Aspire 9.X
And A Nice Clear Lexan Magnetic Dust Boot To Finish It Off.
Old 11-17-2017, 03:31 AM
Michael Mezalick's Avatar
Michael Mezalick Michael Mezalick is offline
CAMaster Owner, (MOD, KOTR)
Sweet,
I'm due for a new boot..
I'll give it a try..
Michael
Michael Mezalick
Cobra, WINCNC
3-D Modeling
https://carveddetails.com/catalog-book/
mm@mezalick.com
Old 11-17-2017, 07:09 AM
tbrookins tbrookins is offline
Very Nice! Thanks for sharing.
I also noticed you have a different laser.. could i get information on that? I have 2 machines and have had trouble with the lasers on both.
thank you
Tracy Brookins
FTC & Laser
T-track
Kent Dust Shoe
Recoil
Stinger II 48x48
1.7Kw spindle
Kent dust shoe
Phenolic top with Hurricane vac & T-track
FTC & Laser
Logictech Rumblepad
Warsaw Indiana
Old 11-17-2017, 07:42 AM
thanks for sharing Steve. we don't have our panther yet, but a magnetic dust boot is on my short list (I think!?!)
Old 11-17-2017, 08:04 AM
Yeah, You'll want a removable dust boot. The one they send you is nice, and it works, but it's sized for a shop vac, and it's kind of awkward. If you have a regular dust collection system, it'll probably have a 4" hose. I reduce it to 3 to concentrate it a bit more.
My laser came from Camaster.. I'd call michael in support if you got it from them. I'm sure those guys can fix you up! Is your's a cutter? or an x/y alignment laser? Mine is for X/Y. But i'm jonesing for a laser cutter one way or another.
Old 12-05-2017, 11:07 AM
ramalyze ramalyze is offline
Default Nice boot
Hey Steve that is a nice dust boot. I am in Alpharetta where did you get the 1/2 acrylic ?
John
Old 12-05-2017, 01:54 PM
R.L.Schulz R.L.Schulz is offline
Awesome! Now can ya fancy one up for the X3?
Ron
Ron & Tammy Schulz
CAMaster Stinger III SR-48
X3 + 2" Gantry Lift + Extended Gantry
HSD 3.0 KW + Counter Balance
Laser Pointer + Tool Measure Switch
Indexing Recoil Lathe
Hurricane Vacuum System
Vectric Aspire 9
Cabinet Planner
Old 12-05-2017, 02:28 PM
Default Quick Disconnect X3 Dust Boot
Having an X3 and thinking of a way I could have a quick change dust boot was a challenge but being an RVír I came up with a way to make that happen!
File Type: jpg 16CA005B-8007-4D27-9E1B-39697182523C.jpg (34.8 KB, 107 views)
File Type: jpg 06203221-370A-47FD-9B9A-D06ED87B1071.jpg (46.0 KB, 96 views)
Ron & Tammy Schulz
Vectric Aspire 9
Cabinet Planner
Old 12-11-2017, 08:33 AM
John
I deal with either Piedmont plastics over on Buford drive, or Calsak in Lawrenceville. Piedmont carries up to 1 1/2"
Old 12-11-2017, 09:13 AM
sgodding sgodding is offline
Machine is looking good, Ron!!
Steve Godding
D&S Artistic Woodworking LLC
