Go Back   CAMheads CNC Router Forum By: CAMaster CNC > CAMaster Machines > Panther Series
Old 04-17-2018, 09:25 AM
ruun96 ruun96 is offline
Default Panther Z accuracy issue
I've got a new Panther PT-408 (rhinocam, wincnc post) that we've only just started trying to run production parts on, and I've got some pretty concerning Z-depth or maybe tool height issues.
Issue 1: Tool height.
When using the probe (measure tool) how accurate can I reasonably expect this tool to be? I can measure a single tool 4 times consecutively and get a different height each time. (+/-0.03") I could measure tools manually with a 123 block I guess, is there a preferred way to measure the tools on these?
Issue 2: Inconsistent cutting depth.
When I cut my spoilboard it was near perfect. but when I'm cutting 3d shapes I seem to lose accuracy over time. My programs run pretty long and after running a nine hour program my z was off by over 0.1". Is this a known issue? Is nine hours too long for this machine? When my program started its' 3-axis finishing it looked great. By the time it was at the end of the program the cutter wasn't even touching the workpiece, just passing about ten thousandths over where it had been roughed. (left 0.01" stock on roughing, and program was checked thoroughly)
I've been cutting and programming these parts on a Haas 3-axis for 5 years, so I'm confident in my program. Other than the spoilboard, I've yet to get a good part off of this thing and I'm getting a little worried...
Old 04-17-2018, 09:41 AM
I can't solve your issue, but I can tell you that it's not normal for these machines. As for the Z height thing, it sounds like something is slipping. I would go straight to tech support.
Old 04-17-2018, 10:00 AM
Ok, So I've called tech support and Michael is telling me I might have a static issue with my dust collection. I'll re-run my job without it and see how that goes. In the meantime has anyone else experienced this? I was told it was not uncommon.
Old 04-17-2018, 10:30 AM
Static is very common. Have you seen, read, and followed this? Including using an insulated standoff that keeps the dust hose from touching the machine?
CAMaster Doc: http://www.camheads.org/showthread.php?t=8650
Video: https://youtu.be/zKzjhp-yDkE
If it happens when dust collector is removed from the system get back here and we can help
Old 04-17-2018, 10:54 AM
hefty hefty is offline
I read that the Panther is servo controlled. If static made a disruption, the closed loop system should self correct. I don't see how a cumulative error could occur like on a stepper machine.
Gary.... what am I missing?
John
John Stanley Stinger II 3'x4', FTC, Laser, 1.7 Kw HSD w/ AB 523 SVC drive, V Carve Pro 8, WinCNC
Old 04-17-2018, 12:05 PM
I've got about two feet of 4" PVC running up the side of the spindle to keep the hose off of it. It has been incredibly dry and windy here also, walking past the router while it was running would get you covered in chips/dust from the static. I'm cutting polyurethane tooling board also.
Thanks for the video link, super helpful.
Old 04-17-2018, 12:39 PM
John...
Those Teknic servos operate on step and direction. Static charges introduce charges that are interpreted as "given steps". This will happen on a step and direction machine more often than on position bases systems where the encoder feedback is direct to the controller.
You are most likely conflating the features of controllers with direct encoder feedback with a closed loom & alarm system.
RUUN96...
Your welcome, but lets see if it solves the problem. There could be something loose in the Z mechanics
Old 04-17-2018, 07:18 PM
I just read through the Teknic Clearpath info and they are calling them closed loop servos with encoders built in the motor. They do mention step & direction for the command signal. Whether they are running Positional or velocity based, there should be corrective action for missed or extra steps. I know you have used this brand and the reason I'm asking is that I want a Panther with ATC for my next machine and I'm really surprised if they are running them open loop. Thanks! John
Old 04-17-2018, 08:02 PM
John...
They are NOT open loop. With the controller in the motor, static discharge in the wire, the onboard drive assumes a step signal.
This is if this is actually happening. They usually will alarm out.
Old 04-17-2018, 08:16 PM
Mine just fault and stop, I reset and move on ,, no damage to material
