Old 05-26-2018, 06:51 PM
Jefoni Jefoni is offline
Default Y2 Thinks it in tripped
I machined a part, moved machine out of the way to approx. Y 60, when I went to move it forward back to zero it tripped low Y limit. The green LED for Y limit is NOT lit, so machine thinks the Y axis hit the low Y limit switch.
Red arrow next to Y on display. When I use L28Y I can move machine backwards but when I try to move it forward it thinks it has already hit low Y limit.
I have checked every connection I know to check. The low Y switch is P0B1 on the machine motherboard, and it has 24 volts like the others but green LED is not lit.
Hope I am making sense. Any direction or guidance would be appreciated.
Jeff
Jeff Searles
Camaster Cobra 408 X3 + 7.5hp Main Spindle + Recoil
Vectric V Carve Pro 7, Aspire 9, Photo Carve,
Cut 2D, Cut 3D
Vacuum Holdown Gentec T3, 15hp FPZ pump
Win CNC Windows 10
www.workagainstthegrain.com
Jefonitoo@gmail.com
http://www.youtube.com/workagainstthegrain
Old 05-27-2018, 07:34 AM
Jeff...
Have you tried jumpering the switch to see if it is bad? Does pressing the switch on/off change the state?
Old 05-27-2018, 12:43 PM
Yes sir...I tried jumping, no change. Pressing has no change. All the others when you press the light on board goes out. For whatever reason the machine thinks the Y2 is pressed in, so the led on board is off and a little red arrow next to Y on WINCNC display.
Jeff Searles
Cut 2D, Cut 3D
Win CNC Windows 10
Jefonitoo@gmail.com
Old 05-27-2018, 01:32 PM
I had an input go bad once on the x switch. In that case had spate inputs on the WinCNC board inside the machine. Moved from the p0b1 in your example to an unused one. Then changed the WinCNC configuration to match.
Just eliminate all possibilities like it sounds you maybe have using a jumper instead of the switch.
Old 05-27-2018, 01:34 PM
Check for loose wire at board end? You could make sure switch works with an ohmmeter and use another input
Old 05-27-2018, 01:49 PM
Charlie, I moved from P0B2 to P1B6 and problem solved.....
Not to sound dense, but what does that mean? That input on the board is bad??
Thanks gents for the assistance.
Jeff Searles
Cut 2D, Cut 3D
Win CNC Windows 10
Jefonitoo@gmail.com
Old 05-27-2018, 04:03 PM
Jeff...
Yes, sometimes an input circuit will take a jolt of static or some other current spike and go bad. Glad you are up and running
Old 05-27-2018, 04:47 PM
Thanks for the teaching moment and can't thank you guys enough. APPRECIATE the help. Have a great weekend!!!
Jeff Searles
Cut 2D, Cut 3D
Win CNC Windows 10
Jefonitoo@gmail.com
Old 05-27-2018, 06:42 PM
Jeff,
This turned out really well because you provided answers to all the questions that go through a persons mind as you start troubleshooting. That is helpful in putting the puzzle together from afar. Glad we could help just a little.
