Old 01-31-2018, 09:42 AM
jbiddle jbiddle is offline
Default bit/cut method for 7/8' mahogany
I need to cut out some parts for a bed frame I'm working on. The rails and stiles will be made from 7/8" mahogany. The top rail of the headboard will have curves on the top and bottom. I'm look at the best approach to use for cutting that part. I was thinking of using a 3/8" compression bit cutting all the way through except for a cleanup pass. My partner thought a 1/4" downcut for a shallow cut followed by a 1/4" upcut would be better. What do you think?
James Biddle
Previous CNC-Panther PT-408
15HP FPZ regen w/starter
Auto relief valve
Vectric Aspire
Old 01-31-2018, 09:45 AM
The part I'm referring to is not the top cap piece, its the part below it. I already have the top cap bent lam glued up using a MDF form cut on the CNC.
James Biddle
Auto relief valve
Vectric Aspire
Old 01-31-2018, 10:01 AM
I would use the 3/8 compression. 2 passes down to .030 with an allowance of .010-.015. Make sure the compression has a CEL > 1"
Old 01-31-2018, 11:14 AM
And then make a final pass to take it to zero?
James Biddle
Auto relief valve
Vectric Aspire
Old 01-31-2018, 11:18 AM
Yes, when you use an allowance offset, of say .010, the last pass (which you can slow down for edge quality) will make a full pass removing the .010 left (on the edge) by previous passes AND the .030 onionskin left on the bottom
Old 01-31-2018, 12:34 PM
Thanks for this thread, James, and your expertise, Gary. This was actually something I was thinking about this morning and last night as I anticipate leveraging my machine for furniture parts, too. Very instructive!
Old 02-01-2018, 01:31 PM
Gary, great recommendations. The cut came out really nice. Top board in the pic was the test board with no last pass and a dull bit. Bottom board was the real cut. Other pic shows two of the more difficult parts for the bed. Oh, and the torsion box for the vacuum press and the roll-around cabinets underneath were made on the CNC as well.
James Biddle
Auto relief valve
Vectric Aspire
Old 02-01-2018, 02:28 PM
Well lookie there! Glad it came out well. Shows that even an old blind squirrel can find a nut every now and then.
Old 02-01-2018, 05:45 PM
Wow..that really did turn out beautifully!
Old 02-01-2018, 08:41 PM
What a difference in cut quality. Kudos to Gary for sharing more excellent advice on how to make a quality cut.
