Go Back   CAMheads CNC Router Forum By: CAMaster CNC > CAMaster Machines > Stinger Series CNC Routers
Old 05-05-2017, 11:12 AM
lowercreekgamecalls lowercreekgamecalls is offline
Default X drive not working
I was about 10 min from completing my first larger sign when it started going straight up and down. The x drive is not working. I can manually push it over with the machine on. I know this is not a good sign but don't know exactly what it is or what I need to do. Any help will be appreciated.
John Hood
Old 05-05-2017, 02:47 PM
Spoke on the phone to tech support which was awesome! Belt had come off. I had to adjust the gear it was not lining up with the bigger gear. Got it back running in less than 1 hour.
John Hood
Old 08-09-2017, 10:36 PM
ievolve ievolve is offline
I have heard several people mention belts. I thought these were R&P machines, where are the belts located?
Old 08-10-2017, 08:06 AM
mikeacg mikeacg is offline
Stinger Owner
John,
Glad to hear it was only the belt! When my x stopped working it was the old 1/4" shaft breaking and I had to practically dismantle my shop to get at it to replace it. Now I have a nice big hole in the bottom of my table so I can get at it to adjust tension and I have an extra motor sitting on my shelf!
It's not like I run my machine every day but I was down for more than a week and started to go through withdrawal...
Mike
Mike Schnorr
Stinger 1 with Spindle and Recoil
Win CNC - Aspire 8.5
Sidewinder Back Knife Rotary
Epilog Legend
www.artcentergraphics.com
www.baconwood.com
Old 08-13-2017, 03:25 PM
CosmosK CosmosK is offline
The belt is for a gear reduction between the motor and pinion
2014 Stinger II (SR-44)
1.7 kW Spindle w/ speed control, Performance kit, VCarve Pro
www.cosmos-industrial.com
>Pen Marking Tools - >Drag Knife
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
