Old 11-29-2017, 07:20 AM
TimberArt TimberArt is offline
Default Waste Board
Just curious what you fellas with T tracks are doing as far as your waste boards are concerned. I'm thinking of cutting some MDF to fit between my tracks and then surfacing the MDF. I don't think I would want to glue the MDF down to the table at this point. Any suggestions?
Bill
Bill Johnes
Stinger 2 SR 44
Win CNC
VCarve Pro
Old 11-29-2017, 10:01 AM
mfirlotte mfirlotte is offline
As you say...I cut and place 3/4 MDF between my T-tracks. However, I do not glue them down. I counter sink screws about 1/2 into the MDF.
Works very well for me but have to be very careful if accidentally cut into the spoilboard. Missed a few screws more than once.
Thinking of gluing next time.
Mitch
Stinger 1 (2014)
1.7Kw spindle / Recoil Lathe
Performance Package (FTC / On-Off via G-code / Laser Cross Hair)
Aspire 8 / WinCNC / Hexagon
Epilog 45watt Laser
Old 11-29-2017, 11:01 AM
If you place ripped pieces on the table and you overlap them on the extrusions a bit, they will hold much better. I am a "glue em down" guy, because when they are used up, just glue another over the top
Old 11-29-2017, 01:54 PM
Sounds like gluing them down is still the way to go. On my hobby machine I drilled holes in the waste board and used insert threads and various fixtures which worked out pretty good. I just want to be able to use the full "milling" size of the table when needed.
Bill Johnes
Stinger 2 SR 44
Win CNC
VCarve Pro
Old 11-29-2017, 03:42 PM
Pete Cyr Pete Cyr is offline
As Gary said cut your MDF to overlap the rails but leave space for the clamp bolt.
I glued mine down and clamped them in place using many drywall screws - when cured removed the screws. - -Then mill the surface.
Pete Cyr
CAMaster Stinger II SR-34 - 1.7KW - FTC
Aspire, WINCNC
Old 11-29-2017, 08:02 PM
Sounds like a plan....thanks guys.
Bill Johnes
Stinger 2 SR 44
Win CNC
VCarve Pro
