Go Back   CAMheads CNC Router Forum By: CAMaster CNC > The Water Cooler > Questions For The Sales Team!
Old 01-10-2018, 02:26 PM
EnvisionIT EnvisionIT is offline
Default Air Compressor Size Required
I am just about to order a new SignPro 408 with ATC. I heard from another party that I must have an 80gal Air Compressor to correctly run the ATC / Z Axis...
I have that in my shop, but was planning on getting a smaller pancake unit (5gal) for the CAMaster unit. One because running the larger compressor adds even more noise...
Does any know if I need that much air capacity to run the ATC correctly?
Old 01-10-2018, 03:51 PM
You will not need the 80 gal compressor to run the ATC, but the 5hp pancake will not work.
The cooling circuit uses ~7cfm @ 4 bar (~60 psi). The toolchange operations, dustfoot and air counterbalance all add a little more when they are in use. I would guess that you need 8-9cfm @ 90 psi to make sure that you don't run low on air pressure during a toolchange, which can be catastrophic.
My recommendation is to use your large compressor to be "safe rather than sorry"
Old 01-10-2018, 05:15 PM
Thanks, guess I'll be plumbing a line over to where the cnc machine will sit. Something to do while I want for it to be delivered.
Old 01-10-2018, 06:08 PM
UglySign UglySign is offline
Originally Posted by Gary Campbell View Post
... I would guess that you need 8-9cfm @ 90 psi to make sure that you don't run low on air pressure during a toolchange, which can be catastrophic.
Gary what would it be like catastrophic? What happens?
Old 01-10-2018, 06:53 PM
Ever jammed an atc collet in the middle of a tool change,,, not pretty
Old 01-10-2018, 06:59 PM
Yup... that's my nightmare scenario. Slide into the fork, not enough air to fully release it, and rapid to the top. Like Jim says... its ugly
Old 01-11-2018, 11:20 PM
jjwdawg jjwdawg is offline
Just one anecdote, so take it for what it's worth, but I use one of these:
https://www.homedepot.com/p/Husky-80...801H/203187346
I have a Panther PT-508 with a 5HP ATC spindle and a mister system. Even when using only one side of the mister at (what I think is) a very low rate to blow chips, I have to turn it off during tool changes to avoid aborting the job with a "low pressure" error. I'll occasionally get pressure errors at random times even without the mister running.
I don't know if my experience is typical or if there's an issue with my compressor/plumbing/regulator/etc. I've had "call CAMaster" on my to-do list for a while :-) I'm prepared to upgrade to a "serious" compressor if needed, but I want to confirm exactly what is required by my setup before I spend any more money on it.
All that said - my advice is: once you've placed your order and know the exact specs of your system, ask CAMaster to specify the PSI & CFM you'll need for the machine, and shop for a compressor that will provide that (plus enough extra capacity to cover any other air needs you have and to provide a little headroom for the compressor so it doesn't kill itself). Hopefully, the system you already have will be plenty.
James Watson
Moultrie Made, Inc.
@moultriemade
2015 Panther PT-508
HSD 5HP ATC Spindle
8-tool carousel
15HP Regen vacuum
Aspire 8.5
Old 01-13-2018, 02:03 AM
Just curious, what pressure are you setting it at? It shows 14 cfm at 90psi...
I have a Quincy 5hp 2 stage unit that pushes 15cfm at 90psi that I'm hoping will do the job...
