  #21
Old 01-30-2017, 04:59 PM
Default 4 zones
Hey Charlie,
Thanks for the input. Some what you're describing -- different zones and more Maple inserts -- is/was in my v5 design. Not sure why I thought v6, the one you reviewed, was better, I'll attach v5. Yes, this means I've been pondering spoil board design way too much/long!
The just-in-case clamp: will think about that. More alignment pins: This is probably one of those more-is-better cases, within reason, so I'll look at that too.
  #22
Old 03-13-2017, 01:38 PM
tbrookins tbrookins is offline
I just bought a Stinger II 48X48 with phinolic top and vacuum from David Mar through this forum.
Charlie, I like the setup you had on your machine when it was new. How well did it work out using T-tracks and vacuum? you mentioned you used clamps with vac. Is that typical? I really need to be able to use both..
I have used Russel's inserts on my Stinger I and they work great! But, I have to know where my clamps are needed and that changes on every job.
Tracy Brookins
FTC & Laser
T-track
Kent Dust Shoe
Recoil
Stinger II 48x48
1.7Kw spindle
Kent dust shoe
Phenolic top with Hurricane vac & T-track
FTC & Laser
Logictech Rumblepad
Warsaw Indiana
  #23
Old 03-13-2017, 01:44 PM
I put MDF on top of the tracks and cut grooves for the tracks. I use them more than the vacuum. I only use the vacuum to hold down sheet goods and most of my cutting is smaller work that I clamp. It works very well. I like that the tracks are not one long track but many short clamps. The MDF helps hold the tracks down because the groove is smaller than the track body.
However, I would seriously consider making a grid of Russell's inserts. Maybe a 5 inch square pattern. Using wood clamps that are 9 inches long you could easily reach most work pieces.
  #24
Old 03-13-2017, 03:23 PM
Thank you all for this information. It will help me decide what method to use.
charlie,
Did you glue your spoil board to the Plenum?
I like how Russel has an area removable to put fixtures so I was thinking of using pins to align the spoilboard and make them removable. I realize his plenum is aluminum and that method might not work on phanolic.
Tracy Brookins
FTC & Laser
T-track
Kent Dust Shoe
Recoil
Stinger II 48x48
1.7Kw spindle
Kent dust shoe
FTC & Laser
Logictech Rumblepad
Warsaw Indiana
  #25
Old 03-16-2017, 09:28 AM
I have another question for using vacuum on phenolic top. The plenum on the machine was machined into 2 inch squares by Camaster. Hurricane vac was installed by Camaster as well. Do I need any closed cell foam gasket material in the grooves?
Tracy Brookins
FTC & Laser
T-track
Kent Dust Shoe
Recoil
Stinger II 48x48
1.7Kw spindle
Kent dust shoe
FTC & Laser
Logictech Rumblepad
Warsaw Indiana
hold down
