Go Back   CAMheads CNC Router Forum By: CAMaster CNC > The Water Cooler > The CAMhead Locker Room! > Charlie L
Old 04-02-2018, 08:29 AM
Originally Posted by Mark Maslonkowski View Post
What kind of bit are you using cut pink foam? I am assuming some sort of ball end seeing you are 3d modeling l. Feed and speed??
Mark,
I did use a 1 inch ball nose traveling as fast as I could and turning about 15k. I don't recall the exact numbers but it was likely set for 200 ipm.
I used aspire. Started with a photo of an egg.
Thanks for the comments.
