Old 12-01-2016, 01:13 PM
dminnery dminnery is offline
Default Router turned off during job
Help, my router turned off in the middle of s job. Luckily I stopped the machine right away so the bit did not break.
I isolated the router and than works just fine.
When I turn the spindle on in wincnc I hear the relay click do that appears to work.
Replaced the plug in back of the gantry and still nothing
Have s message into tech support thought I'd see if I could get a solution here as well. Thanks
David
Stinger1
Porter cable router
2.25 hp Porter Cable Router
VCarve Pro
Old 12-01-2016, 03:11 PM
David
Stinger1
Porter cable router
If you unplug the router, then run an extension cord to the router does that work?
Maybe the router brushes?
Old 12-01-2016, 06:04 PM
Trout Tamer Trout Tamer is offline
You can test the gantry plug by plugging in a light, then turning on router in controller, if the light doesn't come on, it may be a bad plug.
Jim
Jim Meadows
Stinger III SR-48
WinCNC Aspire 8.5 Corel Draw X7
Photo V-Carve
Hurricane Vac Epilog Helix
A woman drove me to drink...
and I didn't even have the courtesy to thank her
Old 12-02-2016, 02:00 AM
Thanks for the feedback, the router was working and the relay was working.
I disconnected all the associated connections in the control box and then reconnected - it worked. Bad connection somewhere.
I ran it for 4 hours today and all is well, thanks to the forum and Camaster support!
VCarve Pro
