Old 03-15-2017, 04:51 PM
kjoiner kjoiner is offline
Default Double checking feeds and speeds for aluminum
I'm cutting some plates in .06 to .125 aluminum (5052-H32). I'm using an Onsrud caribde 1/8" O flute cutter. I just want to check my feeds and speeds.
The SFM from Onsrud is 600-1000 FPM. For an 1/8 bit at 600 FPM I get 19,200 rpm. That seems high but maybe not.
With a tooth load range of .002-.004, if I use .003 and run at 19,200 rpm I get a feed rate of 57.6 IPM.
Do those seem reasonable or should I back down on the RPM and feed? I'm running a Milwaukee router and not a spindle.
I would do 2 passes in the .06 material and 3 passes in the .125.
Kyle
Kyle Joiner
IPA LLC
www.thinkipa.com
Duluth, GA
CAMaster Stinger 1 23
Vectric V Carve Pro
Solid Edge ST10
Old 03-16-2017, 02:35 PM
I ran the part using 18000 rpm and 54 IPM feed and it came out good. I'll experiment with the feed as well.
Kyle
Kyle Joiner
IPA LLC
www.thinkipa.com
Duluth, GA
Vectric V Carve Pro
Solid Edge ST10
