-   General Discussion (http://www.camheads.org/forumdisplay.php?f=45)
-   -   Any solidworks CAM users here? What do you use for post processor? (http://www.camheads.org/showthread.php?t=11240)
kt88saturate 04-06-2021 10:16 PM
I do a lot of work in solidworks and I'd like to use a camaster post processor with the software, but what comes with my stinger 1 isn't compatible. Is this something Camaster can help with? If not, does anyone here have a successful solidworks cam/wincnc setup?
james mcgrew 04-07-2021 08:32 AM
Post Processors are on the software company,, If the software comapnys do not do this then they cannot sell to literally a thousand differnt machines.
Contact Solid works ,, As well there are some here who probably have done this. I never used it direct to machine and that was a decade ago is your version direct to machine ?
james mcgrew 04-07-2021 08:33 AM
Also post some of the code you are trying to use on your stinger here. it will help find the right pp
kt88saturate 04-07-2021 02:18 PM
Thanks for the replies James. I will contact dassault.
Which code do you need? G code or the post processor? For the post processor I have only used the one that comes with vectric v-carve pro 10 so far.
I'm not trying to customize the post processor, just trying to get it to work with solidworks.
