-   Router Bits (http://www.camheads.org/forumdisplay.php?f=73)
-   -   5mm boring speed and feed (http://www.camheads.org/showthread.php?t=10097)
Porter Cabs 08-18-2019 10:58 PM
Anybody have recommendations as far as boring 5mm holes in 3/4" ply.
spindle rpm and plunge rate. Is peck drilling necessary?
I do not have a drilling block. Single 5HP HSD spindle
Thanks for any info
Kyle
Doug S 08-19-2019 07:28 AM
First, I use a 5mm brad point bit for drilling so you don't get any heat or chipping. I run one pass, no pecking at 150 IPM plunge rate. I think I am running 12,000 of the spindle but I can verify that tonight.
Sure wish I had a 5 head boring block.
Ger21 08-19-2019 09:11 AM
If you did, you'd wish you had a 12 spindle block.
I have a 12, and wish I had an 18 or 24.
Doug S 08-19-2019 10:24 AM
Sounds like a group but is in order.
