Its an Aspire file, so CRV3D. It was over 10MB, so I resaved it at a lower resolution to get it down to 8MB, but it still won't post. It might be my firewall at work that isn't letting it through. The firewall is a hardware one, and not something I can change (above my skill level!!). I'll try again at home tonight.
Russell Crawford Cobra 408 ATC with recoil Alberta, Canada www.cherryleaf-rustle.com |
I just raised the download limit on vectric files try again
James McGrew CAMaster ATC 508 The principle of Measure twice cut once has not been replaced by a CNC www.mcgrewwoodwork.com https://www.facebook.com/pg/Mcgrew-W...=page_internal Camera 1 ATC Closeup ! https://video.nest.com/live/esNTrZ fixed 4-27-2020 |
It just tells me "upload fails" now. I'm assuming its my firewall, because I've successfully uploaded many crv3d files before (but from my home computer).
I'll try again tonight.
But I'll explain how I made that model.
Pictures of the steps are below I keep the vectors in two halves for the first part of the modelling, right and left. You'll see the profile vectors extend longer than the actual model will be, and that is just for ease of 'smoothing' later. Pay careful attention to the parameters I used in each modelling procedure, because it makes a big difference if you use 'add to previous component', 'extract from previous component', 'merge highest' or 'merge lowest'. I use most of these at different times. I also do not use 'scale cross section with width' I changed a few minor things after I took some of these pictures, but it gives you the basic idea.
![]() Quote:
Mick, I get this error below when I try to upload pictures. Can you fix please? "Your submission could not be processed because a security token was missing. If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error." I just thought that he was very busy and never followed up. I have seen a number of posts where folks are having the same issue and it seems to be more prevalent recently. I don't think the size of the picture is the issue since comcast severely limits picture size to upload. I hope this helps the admins.
Keith Hyde, Winchester, VA 2016 Stinger 1, 1.7KW HF Spindle HSD Performance Package Pro, Vac, lathe, Aspire 10 Former Marine and retired Seabee Master Chief. Furniture is my hobby not my vocation. hyde.consulting@comcast.net |
Mick May have told me about it yet I can never find anything wrong, most who cannot post or see photos it is a permission problem. This seems to be a problem beyound the forum, I can post files with no problem
Thread Tools | |
Display Modes | |
