Go Back   CAMheads CNC Router Forum By: CAMaster CNC > Tips & Techniques > Molds, Mold making and Pattern work
Old 04-17-2016, 05:12 PM
accross26 accross26 is offline
CAMaster Logo Profile Cut is Offset
Good Afternoon CAMheads. I have a question that I would like some input on. I am in the process of making a bathroom mirror and started on the frame yesterday. I decided to use my Stinger I to cut the mitered corners of the frame for the mirror since I know this would be a sure fire way of getting rock solid 45 angles pretty quick. (My miter saw is not perfect at this despite my sincerest efforts to square it up). I set a profile toolpath the cut the angles as need using the Outside/Right Machine Vector. I used a 0.25" EM for the cut. However, I discovered that the cut was 1/8" offset, half the diameter of my bit. So, since I mitered both ends of the board my board length was 1/4" less than expected. I cut the next boards and had the same issue. Any ideas on why this is happening?
Adam Crosswhite
accross26@gmail.com
CAMaster Stinger I
WinCNC + VCarve Pro + PhotoVCarve
Old 04-17-2016, 05:48 PM
Pete Cyr Pete Cyr is offline
Check to see if you Are set to cut ....on....or ....outside in your profile setup
Pete Cyr
CAMaster Stinger II SR-34 - 1.7KW - FTC
Aspire, WINCNC
Old 04-17-2016, 05:58 PM
Adam...
Pete is spot on. There are 3 things I can think of that will cause your issue:
1) profile Left/On/Right Setting
2) Bit Diameter
3) Machine material location not the same as design
Post your design (CRV file) here or Vectric forum if you don't figure it out
Old 04-17-2016, 07:05 PM
tmouse tmouse is offline
Have you checked to see if your machine move 10 inches if you input 10 inches.
Old 04-19-2016, 10:55 AM
I was setup to cut on the outside/right profile setting, and I double checked my bit diameter with a caliber. I also made sure that my bit was setup as 0.25" in the tool database.
I have not checked that my machine moves 10" when 10" is input. I will do that.
Adam Crosswhite
accross26@gmail.com
CAMaster Stinger I
Old 04-19-2016, 10:59 AM
can you post the file as it was when the problem occured, if vector was not closed it can make a difference
Old 04-19-2016, 11:46 PM
James I think you hit the nail on the head. After you mentioned that open vectors could be the issue I went back and double checked. I had used single lines to mark my profile cuts, and sure enough they were showing up as open vectors. So, I reran the file using rectangles slightly wider than my bit diameter, and cut using the inside/left machine vector. Viola! The lengths were exactly the length they were supposed to be. No more offset. Thanks guys for your input.
Adam Crosswhite
accross26@gmail.com
CAMaster Stinger I
