Old 09-14-2018, 02:25 PM
rideak rideak is offline
Default Z Fuse Blowing
Hi,
My Machine stopped during the middle of a cut this morning. I found that the Z fuse was blown. When I install a new fuse and turn on the machine it immediately blows the fuse again. Any ideas what might be causing this?
Old 09-14-2018, 02:35 PM
What model machine, what size fuse? Stepper or servo?
Old 09-14-2018, 02:39 PM
Stinger III, 5A fuse, I think that it has stepper motors.
Old 09-14-2018, 04:43 PM
I would check the connector just upstream of the motor (power off) to see if there are any black marks in it. Check all the wires near the drive to see if there are any touching or crossed over "hairs"
If not, then plug that motor into the X connector near it and move the motor with the X arrows. Then use a new fuse and see if the X moves with the Z arrows.
With no motor connected, put a new fuse in the Z holder. Does the Z blow again?
That swap out should determine if you need a motor or drive. Drive is suspected. If they don't have one in stock, I do.
Old 09-14-2018, 05:41 PM
Thanks for the input. The connectors by the motor seem fine. Everything plugged into the drive seems fine. Nothing happens when I move the green plug from the Z to the X drive and try to move it with the x controls. Z fuse still blows with no motor plugged in. Seems like this points to both motor and drive, which I think is unlikely. Is there something else that could cause the problem?
Old 09-14-2018, 08:31 PM
Nothing happened when you plugged the Z connector into the X because it still had a blown fuse? Did the drive lights come on?
Looks like you need a drive, but I would verify with tech support first. And double check the motor connector once again, because if there is a loose connection there, that will blow the new drive just as dead as the current one.
