Go Back   CAMheads CNC Router Forum By: CAMaster CNC > New CNC Setup. > materials and bits, collets, etc.
Old 06-04-2021, 03:00 PM
What Gary said...I routinely use much lower RPM for simple drilling toolpaths, typically something like 5-6K RPM.
Old 06-07-2021, 04:27 PM
William William is offline
Originally Posted by Gary Campbell View Post
A bit of clarification here:
Spindle are "rated" at a certain RPM range. What is missing is that they are "full torque rated" at that range. Which means you will have less torque available at lower RPMs. Drilling usually requires a lot less torque than routing. So, in most cases there is more than enough torque to drill small holes right down to 3000 RPM. But in any case it is your job to ensure that the feeds and speeds are proper.
Perfect! Thanks Gary that clears up my miss-understanding.
Cobra Elite 408, ATC, 5 hp spindle, vacuum table, 4th axis, Fusion 360
Old 06-07-2021, 04:33 PM
Thanks Jim. I'm assuming I should try on the lower end to be as close to regular drilling speeds as possible.
Any advice on what I should look out for to indicate I've got the wrong speed? Also can you recommend a good starting place for plunge rate?
William
