Go Back   CAMheads CNC Router Forum By: CAMaster CNC > Video Valt > CNC Machines at Work
Old 04-01-2012, 04:11 AM
Default First cut on my new ATC
Well I finall got my new ATC up and running, here is a short video of surfacing the standard black MDF top, I am only removing .010" and running a 800 ipm
Old 04-01-2012, 10:04 PM
richf richf is offline
So you woke the beast up. No material is safe now. I was surprised to see dust collection from below.
I cut out my first keyholes today on your old Cobra using a 1/4" spiral and and 3/8 keyhole bit. I had to modify G-code to back out the keyhole bit since BobCAD doesn't have a menu item for that. Keith Outten recommended that method. I created a tab profile cutout for the ADA plaques last week, again, no menu item for that either.
I have yet to plane my spoil board, there are a few marks in it but hasn't affected me yet. It is pretty amazing to see how accurate cutting down to the spoil board is. I cut out plaques and barely touch the spoil board even though I completely cut the plaque out.
Can't wait to see more pics of your machine in action.
Rich F.
PrecisionSignandPost.com
BobCAD v25 4th Axis
Corel Draw X5
Old 04-02-2012, 12:33 AM
tonywish tonywish is online now
Machine looks nice Mick. I like the way you have the dust collection set. Any problems? It would seem it might get hot by the dust boot or tangled up in it on a large project.
Tony
Old 04-02-2012, 02:43 AM
Rick Weingart Rick Weingart is offline
Send a message via AIM to Rick Weingart Send a message via Yahoo to Rick Weingart
Better than mine !
Old 04-02-2012, 03:12 AM
Sorry guys I would like to take credit for the dust collection coming from below but the fact is it's only temporarily hooked up ...... this was my first run
Old 04-02-2012, 10:34 AM
Mick, when you calibrate your switch (after surfacing the spoilboard), do you need to remeasure all of your tools?
I surfaced my spoilboard, then calibrated the switch, but when I clicked on router home with another tool in the spindle, the z0 was no longer calibrated to the surface of the spoilboard.
Old 04-02-2012, 10:52 AM
Yes ... You can do one tool at time "measure tool" or "measure all tools". If you break a bit or want to replace a bit manually pull the tool holder then replace the bit then install the tool holder back in the rack. Next call the tool you just replace for example T3 (enter) once the spindle had picked up the tool click "measure tool"
Old 04-02-2012, 11:11 AM
eandico eandico is offline
Mick your wife told me you were not aloud to play with that cnc till you got her "honey do" list done!! HAHA!!
Russ,
I can surface my spoil board and then pick up T1 for instance and zero Z to the top of the spoil board and it knows the rest of the tools.
AS LONG AS YOU MEASURED THEM ALL TO START WITH.
I very rarely measure all tools. I will switch out T1or T2 etc. every so often and remeasure just that tool.
I don't know if I typed that out well but you are welcome to call me and I might be able to talk you thru it better.
740.475.8032
Best,
Nick
www.theeandicompany.com
Old 04-03-2012, 08:09 AM
Nick, I had all tools measured (I have the ATC). When I resurfaced my spoilboard, I calibrated the switch with the the planer bit set to the surface. But this did not automatically set the rest of the tools to that height, so I had to remeasure all of them. Seemed odd to me. Once all the tools are measured, I thought they would all automatically reset to the new Z0 when I calibrated the switch.
Old 04-03-2012, 11:24 AM
JohnnyCNC's Avatar
WinCNC has a command that does automatically update the tools, but I doubt your software is set up for it. It is the M37.3.
Most people just use the M37 for calibrating and then do the measure all tools to reset the tool lengths.
You can see it in the WinCNC manual.
JohnnyCNC
