Go Back   CAMheads CNC Router Forum By: CAMaster CNC > New CNC Setup. > materials and bits, collets, etc.
Old 01-25-2021, 03:50 AM
reals8gy reals8gy is offline
Originally Posted by Kyle Stapleton View Post
How are you holding this down?
I currently don't have vacuum, so the holes are drilled while the perimeter is either clamped or "through screwed." I look forward to the day of laying down the material and moving a valve handle.
Old 01-25-2021, 09:25 AM
Use a compression bit for both cuts. 1/4" works, but 3/8" is my favourite.
When cutting the 3/4" holes, use an inside profile cut with a spiral and an offset last pass (so it spirals down the profile just a little smaller than you need, and then gives one last profile cut around the edge to remove the little excess that was left). This give the fastest, cleanest holes.
I always find that upcut bits give me a rough top edge on MDF.
