Go Back   CAMheads CNC Router Forum By: CAMaster CNC > The Water Cooler > Work we Produce !!!!
Old 08-21-2018, 03:18 PM
Ballistix Ballistix is offline
Originally Posted by The real JP View Post
Is there a certain depth you need for the epoxy to look good?
For instance if I tried to have a pocket .050 deep would it look good and stay in place?
I do shallow fills a lot and .05 is deep enough, but if using dispersion colorants, you might have to add extra for a good saturation. The color of the material that's engraved, can affect the color of the epoxy on shallow pours.
I don't use dispersion colorants, and I also add iridescent. I also use polyester for many projects.
Yes the epoxy will stay at that depth. Epoxies have little to no shrinkage, and remain slightly flexible. I've made auto emblems using both epoxy and polyester, and the epoxy doesn't have the issues of polyester, with the expansion and contraction.
Old 08-21-2018, 03:31 PM
sylvan sylvan is offline
CAMhead owner
Here is a baseball themed rosette on a guitar I made for a major league umpire. All of the red color stitching is epoxy dyed with a "red" color. The depth is .050" so you can see it worked great!
Sylvan Wells
sylvan@wellsguitars.com
Stinger I, SR-23 - Recoil lathe
FTC, Laser
1.7KW spindle
VCarve Pro 8.5
Windows 10
www.wellsguitars.com
www.baystateguitars.com
Old 08-21-2018, 03:49 PM
Your corian inlays are always amazing to see, Bob. Simply beautiful work.
Your work is inspiring me to try some of this on left over pieces from when I did my kitchen. Cant wait to try it.
And Im still waiting on that corian inlay class.
Storm Vacuum
drummerjg@icloud.com
Old 08-21-2018, 08:03 PM
On Corian you might not have a problem. On wood you’d sand thru it as soon as the sander hit the surface. I cut all mine at a minimum of .12 of an inch. After sanding thru a carving on the wood I swore I’d never do it again.
Bob Walters
Lebanon, Ohio
2016 Stinger II SR-44
3.0 kW Spindle
Vectric VCarve Pro 9.xx
www.cool-signs.com
Old 08-21-2018, 08:08 PM
Originally Posted by guitarwes View Post
Looks great. After the epoxy sets, do you surface it flat on the CNC or another way?
I use a sander starting with 80 grit all the way thru 800 and then polish it with a auto buffer.
Bob Walters
Lebanon, Ohio
3.0 kW Spindle
www.cool-signs.com
Old 08-21-2018, 08:12 PM
Vectric contacted me a few months ago and Iím send them detailed instructions on how I made this so they could post it for everyone. If you wanted to drive west Iíd be glad to show you. Itís super simple, the key is the vac hold down and putting it back in the exact spot for the follow up cuts.
Bob Walters
Lebanon, Ohio
3.0 kW Spindle
www.cool-signs.com
Old 08-23-2018, 09:58 PM
Originally Posted by Bob Walters View Post
Vectric contacted me a few months ago and I’m send them detailed instructions on how I made this so they could post it for everyone. If you wanted to drive west I’d be glad to show you. It’s super simple, the key is the vac hold down and putting it back in the exact spot for the follow up cuts.
I cant wait to see the write up from you/ Vectric. And if I am ever in the vicinity of Lebanon, OH I will most definitely try to hit you up for some expert advice. It would be an honor to meet someone with your talent!
Storm Vacuum
Old 08-24-2018, 07:29 AM
Default Epoxy inlays
I do these one to two colors at a time as long as there is no "bleed potential" between colors. basically i leave it on the machine to cure then cut each color separately, ours the colors touch or come real close.
Old 08-24-2018, 12:03 PM
Super awesome stuff.
Bob Walters
Lebanon, Ohio
3.0 kW Spindle
www.cool-signs.com
