Go Back   CAMheads CNC Router Forum By: CAMaster CNC > The Water Cooler > Work we Produce !!!!
Old 09-03-2018, 09:47 PM
Default HDU Sign For Benefit
Rodger MacMunn Is the man! Finally did a texture on a HDU sign. Looks so much more professional and am so happy, canít thank him enough for the guidance. This is for a benefit auction in Columbus, Ohio next week. Iíll post pictures after painting also.
Bob
File Type: jpg 3B198BE3-0E3D-4C9A-A7A3-98384EB79293.jpg (65.5 KB, 185 views)
Bob Walters
Lebanon, Ohio
2016 Stinger II SR-44
3.0 kW Spindle
Vectric VCarve Pro 9.xx
www.cool-signs.com
Old 09-03-2018, 09:49 PM
That looks awesome, Bob!
Roger's textured/pocket technique is pretty nifty and I keep using it over and over again. I've played with the angles a bit and you can get some interesting effects by changing things up, too.
Old 09-03-2018, 10:29 PM
Thanks. What I really liked is, it didnít take 5 hours like my last texturing did.
Bob Walters
Lebanon, Ohio
3.0 kW Spindle
www.cool-signs.com
Old 09-04-2018, 10:22 AM
Very nice cut!
Is the texturing done with a 2D toolpaths instead of a 3D model? Looks too clean and crisp to be 3D.
Old 09-04-2018, 10:46 AM
Yea, that's the "bee's knees" about this method...it's fast...and in HDU you can cut pretty deep in one pass with a .125 ball nose moving along at a good clip, too.
Old 09-04-2018, 10:49 AM
Originally Posted by rcrawford View Post
Very nice cut!
It's a pocket operation. :) You run it twice; the first time with a 35ļ setting on the raster and the second time with a -35ļ angle on the raster. Only the second pass has the "cleanup" round. The step over is set to 91% for both tool paths. That step over is the "secret sauce" that leaves the crisp little "pyramids" of the background.
Old 09-04-2018, 02:06 PM
Red, next grey.
File Type: jpg 6DF066B0-E352-4945-8F26-D59A96128C51.jpg (97.8 KB, 94 views)
Bob Walters
Lebanon, Ohio
3.0 kW Spindle
www.cool-signs.com
Old 09-04-2018, 04:11 PM
Looks awesome, Bob. Glad it worked out for you.
Are the "border" pockets just done with an end-mill? If so, I'll share another "helpful hint"
If you're sick of painting those hi-lite stripes, be they pockets, V-grooves, whatever, use a 90% V-bit & a V-carve toolpath . You still have to paint it, but don't change the colour .... it can be the same colour as the rest of the border, but it will appear darker, because it's "in shadow".
You can also use a 60* V-bit, if you prefer. Other than a steep chamfer, I can think of no other reason to use a 60* V-bit. Since it's the same colour as the surface, a drunk could paint those letters or hi-lites in for you.
Nice effect, & very fast to execute ....
Old 09-04-2018, 04:43 PM
I cant wait to see the finished product, Bob. Your work is always top notch & an inspiration to us "wannabes"
TR's texture trick is such an amazing game changer for stuff. And now I cant wait to try his v-bit trick for painting. Thanks, TR!
I may even quaff a few malted beverages to test his "drunk painting" theory.
Storm Vacuum
drummerjg@icloud.com
Old 09-04-2018, 07:28 PM
Very nice sign Bob, I have a question about the text.
- Is the text V-carved out or is the text cut separate and placed in a pocket.
- How did you get the sharp corners on the "V" and "N"
Bob
