Go Back   CAMheads CNC Router Forum By: CAMaster CNC > CAMaster Machines > Stinger Series CNC Routers > Stinger III
  #21
Old 11-05-2019, 09:27 PM
klipsch klipsch is offline
Originally Posted by guitarwes View Post
Here is the nozzle tip you need.
https://www.mcmaster.com/2906k92
Thank you very much!
  #22
Old 11-06-2019, 01:37 AM
Bruce Page Bruce Page is offline
Joe, Iím packing it. The high tech stick in the bag works well.
Bruce Page
2013 Stinger 1 SR23
Mick Martin Table
Aspire 10, WinCNC
Chips-a-flyiní
brucep128@gmail.com
  #23
Old 11-06-2019, 06:06 PM
Well, I guess a high tech stick is in my future. A full sized gun is kinda awkward IMHO. Thanks for the tip!
drummerjg@icloud.com
  #24
Old 11-06-2019, 08:01 PM
Of course I had problems using a needle to grease those zerks so I bought this.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
  #25
Old 11-10-2019, 05:15 PM
Just wanted to thank you again. Got everything all lubed up today with that nozzle tip.
For others that may find this thread, I am using this cheap gun I already had:
that gun plus some plumbers tape (thread seal), screw in hose, EzPZ lube lock ( https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 ), and the above nozzle to do the trick for the hard to reach Y axis zerks.
  #26
Old 11-11-2019, 11:10 PM
bmilam bmilam is offline
I just put zerks on my machine and bought a needle and flex hose at O'Reillys. Needle works great except that you need one hand to hold it in and 2 more hands to work the grease gun. I just ordered this gun which I hope will make it easier to manage. I like that it is a full size gun so cartridges are easier to get.
  #27
Old 11-12-2019, 09:04 PM
That one handed operation does look nice! If you have time, maybe you can share your experience once it arrives.
  #28
Old 11-13-2019, 12:15 AM
It arrived the next day. I am waiting for the grease to arrive and will try it this weekend. I'll let you know if it is worthwhile.
  #29
Old 11-17-2019, 07:58 PM
I finally got around to using that new gun. Seems to be pretty well made for what it is. I was a little surprised about the handle. The finger lever is solidly attached to the gun and the part that goes in the palm is what you squeeze. Not a deal killer but if it were the other way around the gun I believe the gun would stay more steady. As you pump it, the gun wants to move around a bit but it is still manageable and definitely easier to manage than the traditional lever.
I used the hose that came with it and put my needle on the end. My bearings had no grease in them and it seemed to fill them up in 3-4 squeezes. I have 13 zerks on my machine. It took me about 10 minutes to fill them all except for the screw on the Z. I am going to have to get another needled for that and put a slight bend in it to be able to reach it and get a good seat.
Ended up with easy control so made virtually no mess and probably did the job in about 1/4 of the time that the traditional gun was taking because of using a needle and hose I really would have needed 3 hands to work the old one efficiently.
I would recommend it to anyone looking for one.
  #30
Old 11-18-2019, 07:52 AM
Thank you for taking the time to review and share in depth details. I've had to fight a few times with my big lever, so it is good to know there are better options.
Good luck with the Z. That sounds like a tough fit.
