Go Back   CAMheads CNC Router Forum By: CAMaster CNC > Software > Vectric - Aspire
Old 02-18-2021, 05:56 PM
canadian canadian is offline
Default Version 10.512 post processor
I recently upgraded(finally from version 4.5) to Version 10.512 and am having problems with the post processor.I formerly used Camaster ATC arcs inch. I have tried CamasterToolChange INCH but get an error message of file not found,syntax error. The single tool INCH does work if I save one toolpath at a time.Where can I find the correct post processor?
Eric Maaskant
T Slot table
FTC, Z touch pad
Recoil 4th axis Lathe
Aspire 4.0 Win CNC
Old 02-18-2021, 06:28 PM
The owners section has post processors.
https://www.camheads.org/showthread.php?t=5637
You should also be able to copy the post you had used to the new, my post folder.
Old 02-25-2021, 09:57 PM
Default Post processor moulding toolpath
I cannot run a moulding toolpath using the CAMaster toolchange INCH post processor.I can only get it to work using the CAMaster single tool post processor. It gives me a file not found message. A profile toolpath opens just fine.I am using Aspire version 10.512 Any ideas?
Eric Maaskant
T Slot table
FTC, Z touch pad
Aspire 4.0 Win CNC
Old 02-26-2021, 10:29 AM
I run molding tool paths with no issues using the INCH toolchange PP...something must be amiss with the copy you have.
Old 02-26-2021, 02:16 PM
Ken Rychlik Ken Rychlik is offline
Your processor is calling for a macro that is not there, or not set up the way it wants. Find your old post process in the old version and install that, as Charlie
said above.
Fixing machines and making sawdust.
SW side of Houston
Old 04-03-2021, 09:11 AM
Joe Travis Joe Travis is offline
Default I'm having the same Syntax- Command file not found
I'm having the same problem with tool change files. Started not to long ago. I've had it work on some combined files but not most? I've tried 2019 and 2020 PostP files.
Joe Travis
Sawdust Designs
2015 Stinger II SR-44
Recoil
Pro Performance pkg.
HSD 2.8 KW Spindle with Quick tool change
T-track table
Aspire V8 , WinCNC
Woodworkingnd@live.com
Old 04-03-2021, 12:00 PM
I have tried both old and new tool change post processors without success on the moulding tool path,the only I can get it too work is to use the single tool post processor .
Eric Maaskant
T Slot table
FTC, Z touch pad
Aspire 4.0 Win CNC
Old 04-10-2021, 09:21 AM
Default Found a fix for my problem
looks like I had a couple new tools assigned numbers that where to high for the system. adding the tools to the right type of materials list and lowering the assigned number for the new tools worked. Happy Cutting!
Joe Travis
Sawdust Designs
Recoil
T-track table
Aspire V8 , WinCNC
Old 04-10-2021, 09:32 AM
This is a "feature" that's been around for a long time...it was covered in the training I took after buying my machine in early 2018. I would have preferred a more "unlimited" approach to tool numbers, but 0-9 is the limit. The bottom line is that one must get creative when constructing the tool inventory and then manually change a tool number in a multi-tool setup when there is a conflict. Fortunately, the Vectric software issues a warning when trying to create a file with different tool geometries have the same tool number.
Old 04-10-2021, 04:45 PM
It's possible to have as many tool numbers as you'd like. Look at CNC.MAC
If you don't have an ATC, you don't really care about your tool numbers, as they're meaningless. I have a Vectric Gadget here: https://forum.vectric.com/viewtopic.php?f=51&t=30580 that will automatically renumber tools in toolpaths for you. I have mine assigned to ctrl-F1, and run it before I save a tap file if I've added new tools or toolpaths. Look at page 2 for the latest version.
There's a post on that thread that tells you how to actually just show the tool name in the tool change message in WinCNC instead of the tool number. It's an easy modification to the FTC/toolchange post processor file.
