Old 01-22-2017, 07:58 PM
c4chassis c4chassis is offline
Default Post help!
I have been trying to use Fusion 360 to make a few parts today. The post is setup so the G2 and G3 are modal commands, and my machine will not run these correctly. I think I need to either change my machine config or just modify the post. I have tried modifying the post, but t keeps doing the same thing. Any ideas?
Travis
Old 01-22-2017, 08:25 PM
Travis...
Can you post the header and a few lines of code from your file and what model and year your machine is?
Old 01-23-2017, 06:56 AM
Well, I figured it out after I posted that last night. I (nervously) modified the wincnc.ini file. I simply added a line - arcs=M1 - under the arc type line. Then reran the same program, and It went fine! Thanks!
Old 05-18-2017, 10:09 AM
krossdal krossdal is offline
I think it's best to revoke this thread instead of starting a new one.
I'm trying to get the rotary option to work in fusion when I use the PP that was attached earlier in this thread I get the following error:
Code:
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Thursday, May 18, 2017 1:47:34 PM
Post processing failed.
Can anyone help? Here is my Fusion 360 file - http://a360.co/2qAs2VT and the PP is here.
Kristjan Krossdal
Iceland
Stinger III - 2017
Options and upgrades:
3.0KW HSD spindle, FTC, Laser Cross Hair, Counter Balance, Digitizing Probe, Remote Handheld Keypad, Indexing Lathe and a 6" gantry overtravel.
Software:
Vectric VCarve and Fusion 360.
kristjan@krossdal.is
www.krossdal.com
Old 10-01-2017, 12:47 PM
I finally achieved to make to PP work! Yayy!!!
I can now cut simultaneously on all four axis.
I added those lines to the PP in the onOpen function:
Code:
var aAxis = createAxis({coordinate:0, table:false, axis:[0, 1, 0], range:[-360,360], preference:1});
  machineConfiguration = new MachineConfiguration(aAxis);
  setMachineConfiguration(machineConfiguration);
And removed:
Code:
if (!machineConfiguration.isMachineCoordinate(0)) {
    aOutput.disable();
I need to adjust the toolpath but it works!
Watch a video of the machine do 4axis work
Kristjan Krossdal
Iceland
Stinger III - 2017
Software:
www.krossdal.com
Old 10-02-2017, 12:34 PM
KickIt KickIt is offline
Great work, fantastic results. Will look at the Fusion software, it seems so much more robust for 3d work.
Kevin Stoops
Cobra's 508 ATC
Recoil, vacuum hold down.
Aspire 9, Photo w/Cut-3d, CPP
30W Fiber Laser
TDS Control Keypads - Inventor of the TDS/KRS Keypads
www.krscorporation.com for keypad support home
YouTube Videos
Old 10-05-2017, 01:32 PM
abesau abesau is offline
Question Fusion 360 Stinger I 2014 SR-23 Model
Anyone got Fusion 360 CAM to work with a Singer I yet? I guess I'm looking for the postprocessor file. I see the postprocessor aaronwe posted in 12-05-2014, 12:54 PM would that still be a good file to use today?
Thank you
abesau
Stinger I - SR-23
3.5 HP Milwaukee Router Model 5625-20
Performance Package Pro
Phenolic Table Top
Software - WinCNC
Design Software - CUT2D
Old 10-11-2017, 05:18 PM
This topic will never get old ;)
I think you can use the post I've been fiddling with.
I decided to share the PP I've been fiddling with. I finally got the lead in and lead out commands to work. And the tool orientation works as well so I think that I've made all the features work that the CAM section of Fusion 360 offers.
Download Post Proccessor
Even though it works perfectly for me it doesn't mean it will work for you. Be careful when testing it out. It's not guarantied that it will work for you. USE AT YOUR OWN RISK!!
I've got Stinger III with a recoil lathe and FTC.
Kristjan Krossdal
Iceland
Stinger III - 2017
Software:
www.krossdal.com
Old 10-27-2017, 06:23 AM
Just wanted to release the newest version of the PP I've been fixing.
These are the changes I've made so far:
  • Added property and functionality to be able to use the 4th axis (recoil lathe).
  • Fixed lead in and lead out functionality (there was an issue with lead in and lead out, G2/G3).
  • Added property to be able to use FTC.
  • Fixed rapid movement G0 (all moves were G1 - feed moves).
Download PP
Kristjan Krossdal
Iceland
Stinger III - 2017
Software:
www.krossdal.com
Old 11-08-2017, 06:01 PM
Updated PP
You can now use tool orientation inside Fusion 360 and you don't have to measure tool if you're using the same bit as in previous toolpath.
Download PP
Kristjan Krossdal
Iceland
Stinger III - 2017
Software:
www.krossdal.com
fusion360, post processor
