Old 04-07-2013, 07:53 AM
Pete Cyr Pete Cyr is offline
I would ask for a price from camaster
Old 04-07-2013, 08:23 AM
Mick I know Luca and some of the fellows at HSD (Joey got a kick outa learning I speak Italian ) yet I have had several spindles done at PDS
http://www.pdscolombo.com/
Old 04-07-2013, 10:44 AM
Ouch! Unexpected expenses like that suck!
Bruce Page
2013 Stinger 1 SR23
Mick Martin Table
Aspire 8.5, WinCNC
Chips-a-flyin’
brucep128@gmail.com
Old 04-07-2013, 12:05 PM
Brian O Brian O is offline
First off I hope you were clear of any flying shrapnel and are ok. By the looks of the parts that cutter was there for a while. How did you shut down the machine. Is there an emergency shut off button easily accessible on the router for this type of situation?
Old 04-07-2013, 01:55 PM
eandico eandico is offline
Some have asked why they can't get their spindles closer to the head stock.
This is the reason why camaster sets tthe limits away from the head stock to avoid collision.
I have changed my setting as well and could also Have a collision. Just a word of warning.
Sorry Mick!! That is the kind of $$$$ I hate to spend too.......
Best,
Nick
www.theeandicompany.com
Old 04-07-2013, 03:16 PM
There are three ways you can stop and CAMaster machine, I have an extra way.
1. Press the spacebar on your keyboard, this will pause the machine the spindle/router will still remain turning but it will stop any movement on the axis's
2. Press the ESC button on your keyboard, this will stop the machine and turn off the spindle/router.
3. Press the red emergency button on the control box this will do the same as #2.
4. I also have a wired keypad (pendant) that I operate my machine with, it also has a pause and a stop button.
I always keep my finger by the stop button on my wired keypad for the first few minutes while running a new file .... just in case. I was able to stop the CNC within a second or two. I was running the spindle a 16,000 RPM and a feed rate of 200 in/min.
I know why it happened (which is a good thing) during my design in Aspire I set X0Y0 in the center of my design, when I created my toolpath it also created X0Y0 in the center. So when I loaded the .tap file into Wincnc and and ran the file the router bit went to the lower left hand corner to start cutting. I was using the lathe say for example my work piece was 10" long and I have my router 5" away from my chuck it wouldn't have been a problem, instead I had the router bit say 1" away from the chuck. There is a preview button on the Wincnc screen that shows where the router bit is going to travel, I always use it but this time I missed it.
I have attached a picture below, on the left is a design where X0Y0 is the the center, on the right X0Y0 is in the lower left hand corner. One of the golden rules when creating and design and running it on the CNC is to have X0Y0 in the same position on your machine.
Here is the preview in Aspire and a preview in Wincnc, in the Wincnc preview I have colored my table with a red line. You can see the design goes off the table, if I had run my project on the table I would have gotten an error message because Wincnc runs the file 1000's of code lines in advance.
Here is the correct way I should have done it.
Old 05-11-2013, 07:12 PM
bmc0787 bmc0787 is offline
Hi Mick
Did you get the spindle repaired yet?
Just wondering if it was a rebuild or a new spindle
Old 05-13-2013, 10:43 AM
I actually got my Spindle back last Friday May 10th but was in Montana over the weekend so I will be installing the rebuilt spindle this evening.
I am paying for the spindle overhaul myself but CAMaster helped my with contacting HSD and all the paperwork, thank you Thomas and Jim.
Old 05-16-2013, 10:30 PM
Thumbs up Update - update
I installed my overhauled spindle and did some minor adjustments in the alinement, I ran a few test cuts then milled my spoilboard 14 minutes and 4 seconds for a 5 x 8 table. I removed .015, 1600 rpm and 700 in/min.
Old 05-16-2013, 11:16 PM
Mick, I'm glad you have it running again. I hope this down time gave you a chance to get acquainted with your new laser.
