Old 05-08-2016, 03:23 PM
fcfoley fcfoley is offline
Default "A" axis rotation problem
So I finally tried to use my rotary and ran into a problem. A-axis rotation is sporadic. It's hard to describe but I'll try. I set VCarve for a simple rounding tool path which was going to use a 1/2 end mill and travel down the Y axis as the blank rotated on the A asis. It began ok with 2 nice clean rotations then as it traveled down the Y axis the A rotation got incrementally smaller and smaller.
I aborted the process and stated to mess around. One thing I found out was in WINCNC using the A keys will move the A-axis momentarily while the position indicator continues to show rotation but there is no movement. Not sure where to look for the problem. Attached is a picture to illustrate what happened.
Frank
Frank
Stinger II (SR-44)
Index Lathe
Old 05-08-2016, 03:57 PM
JohnnyCNC's Avatar
Post your tap file.
JohnnyCNC
Old 05-08-2016, 04:39 PM
Johnny,
I've attached the tap file. Question, shouldn't I be able to move the A axis via WINCNC like moving along the X and Y?
Additionally I've tried rebooting the computer and the stinger. I've also zero'd A.
Thanks again for your help
Frank
Frank
Stinger II (SR-44)
Index Lathe
Old 05-08-2016, 05:34 PM
JohnnyCNC's Avatar
The WinCNC viewer is 2 dimensional. It only shows X and Y moves. Even Z doesn't show on the viewer.
JohnnyCNC
Old 05-08-2016, 06:36 PM
Sounds like a loose connection?
Old 05-08-2016, 06:37 PM
JohnnyCNC's Avatar
File should work.
JohnnyCNC
Old 05-08-2016, 07:02 PM
Unfortunately, I'm doing better job of confusing the problem then explaining it.
In the 1st attached image I'm referring to numerical location that X,Y,Z and A are at. When you manually drive any of these X,Y,Z as the machine moves so does the numerical location. I am not seeing this with the A axis. I'm almost certain that some months ago when I was just playing around, I could get the rotary to move just by manually selecting the A buttons. I can't figure what has changed.
In the 2nd image, A axis was advanced to 2580 with no movement. If I continue to advance A axis I will get sporadic moves but nothing consistent. I've zero'd A out multiple times and there is no consistency as to when the A axis will rotate.
Frank
Stinger II (SR-44)
Index Lathe
Old 05-08-2016, 07:10 PM
Gary, I've reseated the cable from the computer to the machine. I've reseated the WINCNC card, I reseated the connection on the servo motor and the connections on the rotary controller appear tight.
Frank
Stinger II (SR-44)
Index Lathe
Old 05-08-2016, 07:38 PM
Michael Mezalick's Avatar
CAMaster Owner, (MOD, KOTR)
Frank,
My guess is that there's a loose wire somewhere..
Check them all again, even if it looks tight..
Looks can be deceiving..
Michael
Michael Mezalick
Cobra, WINCNC
3-D Modeling
https://carveddetails.com
mm@mezalick.com
Old 05-08-2016, 08:30 PM
Frank,
Another thing to check is that the chuck is firmly connected to the spindle. I have had a similar failure and it was because the chuck would move under heavy load.
I've also had the rotary drive "skip"/"slip"/something-a-rather a couple times (and we have the same machine). To avoid the this, I've adopted a lighter approach -- slower speeds, 1/8" or less cut depth, etc. This, along with using a firmly-attached, better chuck, has eliminated the problem for me and I produced a few pieces that looked like your sample.
Cheers
