Old 06-18-2018, 10:26 AM
kjoiner kjoiner is offline
Default Chamfers and countersinks - setting size
Hello,
When countersinking using a V bit, or countersink bit, does Vectric have a setting that can determine the depth of cut to achieve the desired diameter or is it just a matter of doing a little trig?
Kyle
Kyle Joiner
IPA LLC
www.thinkipa.com
Duluth, GA
CAMaster Stinger 1 23
FTC, Laser Cross Hair
Vectric V Carve Pro
Remote Handheld Keypad
Solid Edge ST10
Old 06-18-2018, 11:02 AM
TinKnocker TinKnocker is offline
My daytime job was working in a metal shop, which used a router as one of the metal cutting methods. We found that countersinking with the router did not give the .005 tolerances we required for our stuff. The problem is that a small increase/decrease in depth has a much larger affect on the hypotenuse. We end up using the drill press with a micro-stop to get the correct countersink depths. I wonder if combining the router with the micro-stop might work, but I would worry about the pressure it could apply to the Z-axis.
-PETE MALONE
SR-34
V-Carve Pro V8
1.7kw Spindle, FTC and counter balance and T-rails
Recoil Ready
Old 06-18-2018, 12:43 PM
Brian O Brian O is offline
I don't know trig but here's my method. I draw two parallel lines setting the intended depth with two angled lines for the countersink in this case and then measure or adjust.
Brian O
stinger III x3
vcarve pro
Old 06-18-2018, 01:01 PM
Pretty much. I thought the chamfer toolpath would work, but I can't get it to cooperate. (Works in v8.5, but you must use a square end mill...So, nope.)
Attached graphic should get you going.
-B
Old 06-18-2018, 01:42 PM
Jim_in_PA Jim_in_PA is online now
Ooh...thanks for that Brady!
Old 06-19-2018, 04:37 PM
Thanks for all the replies. I'll just calculate the necessary depth for the cutter. Now that I have the FTC activated on my machine, I'm starting to think about other processes and possible tool changes.
Kyle
Kyle Joiner
IPA LLC
www.thinkipa.com
Duluth, GA
Vectric V Carve Pro
Solid Edge ST10
Old 06-26-2018, 07:26 AM
BrianM BrianM is offline
Hello,
Kyle
The VCarve toolpath will calculate the correct depth based on the diameter of your selected circles and the angle of your tool as long as you can 'drill' the whole depth in one pass.
If the depth of the countersink exceeds the pass depth set for the tool, the VCarve toothpath will make an extra circular pass which your are unlikely to want.
Brian
Old 06-26-2018, 09:12 AM
Hi Brian,
Thanks for the tip. I'll create a test toolpath and try it out. :)
Kyle
Kyle Joiner
IPA LLC
www.thinkipa.com
Duluth, GA
Vectric V Carve Pro
Solid Edge ST10
Old 06-27-2018, 11:43 AM
JohnnyCNC's Avatar
JohnnyCNC JohnnyCNC is offline
Send a message via Skype™ to JohnnyCNC
If your V-Bit is the correct angle and is large enough to cut the diameter of the countersink in one pass (i.e. - 1/2" diameter hole and 1" diameter tool) you can take half the diameter of the hole and divide it by the tangent of half the angle of the v-bit (60 v-bit, use 30 for the angle... 90 bit, use 45) to get the depth to plunge.
Those tangent numbers would be approximately 0.5774 for the 60 bit and 1 for the 90 bit.
So if we had a 1/2" diameter hole, we'd do 0.25/0.5774=~0.433" depth for the 60 bit and 0.25/1=0.25" depth for the 90 bit.
You can even plug these numbers into the Drilling Toolpath dialog and let it calculate depth for you.
JohnnyCNC
Old 07-23-2018, 04:18 PM
Hello,
I finally tried out the countersink and it worked well. Beats having to set up a drill press or mill to cut the correct depth.
By the way, I found a countersink that works well on plastics - in my case UHMW but I'll also be using it for other plastics as well - maybe even aluminum.
It's McMaster Carr p/n 2742A22. It has reasonable sharp flutes and cuts clean countersinks. I used the drill toolpath and cut down .287 to get a .500 countersink.
Kyle
Kyle Joiner
IPA LLC
www.thinkipa.com
Duluth, GA
Vectric V Carve Pro
Solid Edge ST10
