Old 04-03-2018, 06:37 PM
Default JointCAM + CAMaster users?
I'm seeing a problem with JointCAM, which may be caused by my not getting the configuration correct for a Stinger. So..... I'd like to see if there's anyone here that uses JointCAM on their CAMaster so I can confirm configuration/etc.
The specific issue I'm seeing is that the XY feed rate is not set for blind dovetails. The Z feed rate gets correctly set, but the XY feed rate is undefined for the initial/roughing tool. When the second/dovetail tool is installed the XY feed rate is set as expected.
I have reached out to Gerry on this, but he doesn't use a CAMaster machine so I'd like to confirm my setup/configuration with someone that is not having this problem on a CAMaster.
Thanks!
Stinger II, Aspire, Sketchup, www.DavisonWoodworks.com
Old 04-03-2018, 09:37 PM
This was due to a small bug in JointCAM, which has been fixed.
Old 04-04-2018, 08:45 AM
Thanks Gerry! That was lightning fast. Looking forward to poking around with JointCAM and seeing how badly my vertical jig works.
