Old 05-01-2018, 09:10 AM
kjoiner kjoiner is offline
Default Adding air line to Stinger
I'm planning on adding some Loc Line to my Stinger to blow chips away when machining aluminum. As far as running the air line on the machine, I want to run it inside the cable chains to feed it up to the Z axis. There are a lot of choices for tubing from polyester reinforced PVC to Tygon etc. I was just curious what type of tubing to CAMaster uses when feeding a Z axis counterbalance cylinder?
I'll be running pretty low pressure -probably 20-30 PSI max.
Kyle
Kyle Joiner
IPA LLC
www.thinkipa.com
Duluth, GA
CAMaster Stinger 1 23
Vectric V Carve Pro
Solid Edge ST10
Old 05-01-2018, 09:19 AM
You can use either nylon or polyurethane. the nylon is similar to refrigerator water tube, the PUR is available at McMaster Carr
Use 100 psi rated tube
Old 05-01-2018, 09:41 AM
Hi Gary,
Thanks for the recommendations. I'll check it out.
Is the polyethylene tubing like you find at Home Depot or Lowes too stiff?
https://www.lowes.com/pd/EASTMAN-1-4...ing/1000180489
Kyle
Kyle Joiner
IPA LLC
www.thinkipa.com
Duluth, GA
Vectric V Carve Pro
Solid Edge ST10
Old 05-01-2018, 10:06 AM
It could work, but have never tried it. As a rule, I NEVER buy anything from a big box store that I can get thru another supplier.
