Old 06-01-2018, 03:16 PM
Steve Burke Steve Burke is offline
Default Need help with Vectric Cut 2D
I posted in the Vectric forum and received answers, but so far I am still unable to do what I am trying to do. I am trying to mill out the area between the letters and between the letters and the line above and below the letters. Any help would be appreciated.
The letters are not grouped together. I have tried converting them to curves, but that only allows me to separate the inner part of the B from the outer lines. I want to stop at the point where the letter meets the upper and lower lines.
Stinger 1 SR-23
Windows 10
Vectric VCarve Pro
3.5 Milwaukee router
Prepped for recoil
Old 06-01-2018, 03:55 PM
Copy the letters and the lines to another layer, and trim the lines and letters to make closed vectors of the areas you want to machine. Use these new closed vectors for your toolpaths.
Old 06-01-2018, 04:12 PM
You will have to generate a rectangle that is slightly wider than the letters and as high as the lines above and below to form the outer machining boundary. Then select the boundary AND the letters for a pocketing toolpath.
Old 06-03-2018, 11:11 PM
Ok, with all the different suggestions I have it figured out. I have to
Make it a curve, node edit, add points, cut points, make it a vector then select it for cutting.
It's a lot of steps but I got it to work.
Thanks everyone.
Stinger 1 SR-23
Windows 10
Vectric VCarve Pro
Prepped for recoil
