Old 07-12-2018, 09:10 PM
Steve Burke Steve Burke is offline
Default Ramping into the material with Cut2D
Is it possible to ramp into the material using Vectric's Cut2D? I want to be able to mill into wood but so far I have not been able to do this with this program. The only thing I've been able to do is plunge into the material.
Stinger 1 SR-23
Windows 10
Vectric VCarve Pro
3.5 Milwaukee router
Prepped for recoil
Old 07-13-2018, 08:03 AM
Ramping values should be in the toolpath toolbar . Have you set the ramp values and checked the "add ramps to toolpath" box ?
Herb Holmes
Performance Pkg
Slotted table
WINCNC
Aspire 8.505
Porter Cable 2.25
CAMaster Stand
Old 07-13-2018, 08:23 AM
You may have to check "Advanced Toolpath Options" to be able to see the ramping dialog box
Old 07-13-2018, 09:46 PM
Did you find your answer as Gary noted?
Old 07-14-2018, 04:56 PM
So far I have not been able to get the program to do what I want. I am using Cut2d. I have tried using the ramp values in the program but so far have not been able to make it work.
What I am trying to do is to make a star using a V bit, by plunging into the center and ramping up and out to the star points.
Stinger 1 SR-23
Windows 10
Vectric VCarve Pro
Prepped for recoil
Old 07-14-2018, 06:08 PM
Steve, I think you are getting confused on terminology. Ramping is for slowly starting a bit into your material vs plunging and then starting to cut. The process you are describing will occur naturally using the vcarve tool path. The bit will plung deeper into the material at the center of the star and pull up as it gets to the points to make nice sharp edges. It may even start at the edges and plunge to the center depending on the vector and other parameters set for the cut. Depending on any depth of cut you may have specified and the distance between the vectors you may see very little plunging or quite a bit.
Or am I misunderstanding your issue?
Storm Vacuum
drummerjg@icloud.com
Old 07-14-2018, 06:39 PM
From what I can tell, what I am trying is a fluting type move. So I went ahead and upgraded to VCut pro and have already successfully made a star the way I want, and have already made a 50 star array for a flag.
When you have the right software anything is possible.
Thank all of you for trying to help me.
Stinger 1 SR-23
Windows 10
Vectric VCarve Pro
Prepped for recoil
Old 07-14-2018, 09:43 PM
Thats good to hear! It only took me 3 days to move up from Cut 2D. I think you will be much happier. I would love to see the flag you cut when its done...even just the 50 star array if you care to post.
Storm Vacuum
Old 07-15-2018, 01:57 PM
Will do. I have to go get the material first. :)
Stinger 1 SR-23
Windows 10
Vectric VCarve Pro
Prepped for recoil
