Old 07-23-2018, 09:05 PM
genejameson genejameson is offline
Default Wincnc newb question
I am getting the hang of my new camaster but I do have a question about wincnc. I run mainly short jobs then remove parts, replace them with new parts the rerun the same job. On my old mach3 machine rerunning the same job was one click of the mouse. With wincnc I click on restart then a window pops up and I select the most recent file then enter line number 1 in the start at line number dialog box then hit enter, then enter again. Is there a one click option or command that I can use or is there a macro I can create to do this? Any advice appreciated, thanks.
Gene
Old 07-23-2018, 09:48 PM
krossdal krossdal is offline
I most often use TAB and then hit Enter and probably Enter once again.
Kristjan Krossdal
Iceland
Stinger III - 2017
Options and upgrades:
3.0KW HSD spindle, FTC, Laser Cross Hair, Counter Balance, Digitizing Probe, Remote Handheld Keypad, Indexing Lathe and a 6" gantry overtravel.
Software:
Vectric VCarve and Fusion 360.
kristjan@krossdal.is
www.krossdal.com
Old 07-24-2018, 08:16 AM
I hit the <ENTER> key.
Double click the file.
Hit <ENTER> again.
Old 07-24-2018, 10:18 AM
CNC Consultants and Trainers
If you have the WinCNC pendant you can simply press the "Repeat" button
Old 07-24-2018, 06:20 PM
I would like to know more about this pendant you speak of.
Old 07-24-2018, 06:33 PM
Gary posted a YouTube video of it yesterday along with a link to the video. Pull that up and you are in business!
Old 07-24-2018, 07:53 PM
https://youtu.be/YhguEASCaSE
Old 07-25-2018, 02:23 PM
Thanks Gary, I will be getting one of those.
Gene
Old 07-25-2018, 03:55 PM
Gene, Gary can get you setup with both the device and the programming...he's a good resource to work with for this kind of thing because it's not "plug and play".
Old 07-26-2018, 07:11 AM
Tristan Tristan is offline
Send a message via Skype™ to Tristan
Gene, in WINCNC you can click on "Options" then check "Auto Repeat". This will, after the job has been cut, place the same program into the cue, so all you nees to do is hit enter... We also run our programs over and over again. I have also wired a pushbutton onto my older CAMaster to di the same thing as the enter button, to make it easier for the operator
Tristan Brammer
CAMaster Cobra CR-609 ATC
2018 CAMaster Elite CR-609 ATC
WINCNC
Enroute 4 and Aspire v8 Design Software
AutoCAD, Autosketch, Sketchup
Razor CNC
Aspire v8
"Sawdust means Work in Progress"
