Old 08-25-2018, 07:42 PM
Default Wincnc Screen Modifications
I have been tinkering with some minor changes to my wincnc screen, making it bigger, moving buttons, etc. Iíve gotten some excellent help from Mike Davison on button layout (thanks Mike!). I have figured out that I need a new background file to lay my new screen layout into...and I have it all drawn out in MS Paint. Whats driving me to drink is how do I point to that new bakground bmp so that the CNCSCRN file will pick it up? Im hoping the experts can save me before Im fitted for a straight jacket!
Storm Vacuum
drummerjg@icloud.com
Old 08-25-2018, 08:46 PM
Joe...
The OEM background file is named "Back.bmp" Save a copy of that and name your new one "Back.bmp" and you should be good to go.
Old 08-25-2018, 09:13 PM
Joe...
THANK YOU!!! You saved my sanity, Gary. I knew it must be something simple, but being simple myself I couldnt quite ď figger it out ď
A follow up if I may....
Is there an easy way to expand my viewer screen? I doubled the width of the standard section and my 25 x 48 grid only shows up in half of the defined space.
Storm Vacuum
Old 08-25-2018, 09:32 PM
Joe...
The locations and size of all screen elements can be changed. Once you get used to it, not so bad. If you cant get it changed to your liking, post a screen shot
Old 08-26-2018, 11:16 AM
This line, from cncscrn.ini, defines a 1040x768 window. Adjust as you like.
"Display", "Main Window", 0, 0, 1040, 768
Old 08-26-2018, 12:15 PM
If I wanted to put a vacuum I/O button on using a relay in the control box. How do I find that relay in the software?
Old 08-26-2018, 01:36 PM
See the docs on M11 and M12. Hereís how I did it:
http://www.camheads.org/showthread.php?t=7513
Old 08-26-2018, 06:49 PM
Thanks, Gary and Mike.
I am getting better (dangerous?) at making screen modifications thanks to your help. Im still struggling with sizing the viewer that shows my table grid. Since I have a 24x48 table it only shows in half of the screen area. But....I want to fight through it and see if I can figure it out. What I have now works...its just a nit that drives me slightly nuts. If I give up I will be back with a screen grab.
Again, many thanks for the help!
Storm Vacuum
Old 08-26-2018, 09:06 PM
Some of the WinCNC screen layout commands are absolute position while some are sizes. Some have built-in, undocumented small offsets, some do not. Laying out a new screen really requires some trial and error. You might be getting tripped up by sizes vs positions. Not sure.
Some cryptic notes I've gathered:
"Display", "Title", "VisualCNC Control Panel"
"Display", "Main Color", 180, 180, 180
"Display", "Main Window", startX, startY, endX, endY
"Display", "Position", left, top, width, height, 1 [+2 to left and top]
"Display", "Viewer", left, top, width, height [+2 to left and top]
"Display", "Command", startX, startY, endX, endY [+2 to startX and startY]
"Display", "ButtonSet", startX, startY, endX, endY [+5 to startY]
screen, wincnc
