Old 01-02-2020, 10:00 PM
locaholic35 locaholic35 is offline
Default Cad Model of Cobra?
Hi guys,
Does anyone have an STL file of a Cobra Elite 5x10 that they can share? I am hoping to make a 3d print at 1/32 scale to play around with workshop layout.
Happy New Year!
Anthony
Anthony Q
San Francisco, CA
Old 01-03-2020, 08:07 AM
Doug S Doug S is offline
I doubt a 3d model exists but I have access to a 3D scanner and could scan a unit and develop a model fairly easy.
Sounds like a good weekend project.
Existing:-2014 Cobra 5x10 ATC w/ 10 hp spindle, Mozaik, 25 hp Becker High Vacuum Pump, 5 HP Oneida DC-Central Texas
New:-2014 Cobra 5x12 ATC w/ 10 hp spindle, pop up pins, phenolic top, lathe, vacuum relief valve, mister system, 25 HP Blower.
Old 01-03-2020, 06:21 PM
Just be sure to double the space around it that you think you need.
Old 01-04-2020, 10:31 AM
You could probably build one reasonably quickly with SketchUp or similar from the drawings and dimensions that Camaster typically has on their web site. It might not be "detail level" pretty, but for a shop layout, it might work. I did that for my slider and J/P years ago for some shop layout frolic.
