Go Back   CAMheads CNC Router Forum By: CAMaster CNC > Tips & Techniques > metal work
Old 12-03-2015, 01:05 PM
David Warkentin David Warkentin is offline
Default Anodized aluminum engraving
One of my first jobs for the new machine is going to be engraving some names on small anodized aluminum tags. Will I need a diamond drag bit for this? Anybody have any experience with this? I searched but most seem to be on plain aluminum.
David Warkentin
Panther 4x8
Laser cross hairs
Recoil
Hurricane
Sold-
What a load of fun!!!
www.bodkacoffee.com
Old 12-05-2015, 08:15 AM
homersmth24 homersmth24 is offline
I have never engraved anodized aluminum but I have done a lot with raw 6061. I would recommend a good solid carbide 60 degree V bit. In my experience .009" deep 16000 RPM and 9 IPM turns out really nice.
Homer F. Smith
HomerS@carnaeder.com
Stinger II SR-44
3.5 HP Milwaukee Router
Performance Pro Package
Nema 34 900 oz Motors
4th Axis Ready
2" Gantry Lift
Graphtec CE6000-120 Vinyl cutter
BossLaser LS3655 150 watt
AutoCAD
VCarve Pro 8.0
Photo VCarve 8.0
CorelDraw 2017
www.carnaeder.com
Old 12-05-2015, 08:34 AM
TinKnocker TinKnocker is offline
I am interested to hear the results. I tried engraving some durablack which I suspect is anodized and it didn't penetrate enough. Some areas it did and some it didn't. I have not tried Homer's method at all, I didn't think you could use a v-bit on aluminum.
-PETE MALONE
SR-34
V-Carve Pro V8
1.7kw Spindle, FTC and counter balance and T-rails
Recoil Ready
Old 09-26-2020, 12:19 PM
Racegrafix Racegrafix is offline
The diamond drag bit will work, but its very fine. I use a spot drill endmill and do a light pass, typically this gives perfect results. The drag is usually not deep enough. Both work.
