Old 10-27-2018, 03:12 PM
Default FTC Z0 Question
Help....I need someone to point out the elephant right in front of me, because I cant see him!!
I just installed a Storm Vacuum on my SR24 (and I LOVE it).
To remove my old glued down spoil board I had to mill it totally away. No issues whatsoever. I did disconnect my FTC switch to move it out of harms way. I then installed my new Trupan bleeder/spoil board. I surfaced both sides and then reinstalled my FTC switch. I made sure any boxes, blue or green were gone in the position window. I set my bit on my spoil board and hit calibrate switch. All worked as expected and I now have a blue box next to my z setting. If I hit zo the bit comes nicely down to the spoil board....so far...so good.
I went to run a simple v-carve file. Set my Z0 to the spoil board, loaded my tap file and the after putting in the v bit it went over and did its measurement. Then off it went to the piece on the table...and the bit does not come down far enough to do its carving. Its just ever so slightly above the wood. I have tried everything I know...g49, g92, g92.1 zo....gee I wish I knew what the heck was wrong!
If I set Z0 to the top of the piece...all works well...but if I use the table as Z0 I never get to the surface of the wood. And it all worked flawlessly before the Trupan install.
Im not getting any exceeded limit warnings either...fwiw.
Ideas???
Storm Vacuum
drummerjg@icloud.com
Old 10-27-2018, 04:21 PM
I admit I got a bit turned around reading your post so I may get this wrong.
You recalibrated switch after milling your new spoilboard right?
Then you measure tool
When you hit the calibrate switch button the bit should be jogged down to the spoilboard. Then when you measure tool this set's your tool offset.
Check the ol material surface and machine bed setting in Vectric as well.
Old 10-27-2018, 05:44 PM
Yup...I did the calibrate switch after milling the spoil board.
Then when I load the tap file. it asks for the bit...I install...and it then goes to the FTC switch to measure that bit. Then off to the workpiece but never plunging far enough to actually carve into it. It just does it thing about 0.001" above the workpiece.
I checked, double checked even triple checked the settings in Aspire. They show the spoil board as Z0. This is driving me absolutely nuts!!
Storm Vacuum
Old 10-27-2018, 06:18 PM
In your file, what is the reference set to...top or bottom of material?
Old 10-27-2018, 09:06 PM
I have had that happen before. I don't remember specifically what I did. Just re-initialize and redo everything.
I also sometimes hit the home button instead of xy zero and mess up my z...
Old 10-27-2018, 10:59 PM
Default Fwiw
Joe, is this an old tap file that you change the parameters or is it a new tap file?
I have found that sometimes just changing parameters in Vetric or Aspire doesn't work. I have also found that sometimes I have to close out of WinCnc and open again to have the program memory be deleted.
Some software programs will remember previous inputs and you have to close out and/or shutdown to delete. I have found this especially with tools in tool path. FWIW.
Old 10-28-2018, 10:01 AM
Originally Posted by keithrhyde View Post
J
I had this happen this week as a matter of fact, and it wasn't the first time.
Old 10-28-2018, 03:03 PM
It was a new tap file although it was made from an old crv file. I basically changed the size of the material. I have done that numerous times before without any issues. So far I have tried powering the Stinger on/ off, reseating and cleaning the db25 connector, deleting the existing info from running the calibrate switch command, restarting wincnc.....nothing seems to make a difference. Im truly stuck as to what to do next. There must be something simple I am missing.
Storm Vacuum
Old 10-28-2018, 03:07 PM
After you calibrate switch and measure tool.
What happens when you type Z0 ?
Old 10-28-2018, 03:08 PM
I hear you....I have done that enough times so that I finally moved my Home and Park buttons. I also now use the KRS keypad and laser to set my X0Y0 to avoid that.
Storm Vacuum
