Old 11-16-2018, 09:44 AM
Tristan Tristan is offline
Send a message via Skype™ to Tristan
Default Ac drive fault
Good day all
I have a funny problem that has crept into my Elite. I constantly get a "AC DRIVE FAULT, RESET SERVOS" error. I have greased the bearings and cleaned the linear rails, checked that there was nothing causing resistance. I even ran the machine "in the air", to rule out too much resistance from the cutter, but to no avail. Everytime the error comes up, it stops the machine, and I have to initialize, and then I can carry on. It happens quite often (sometimes up to 8 times on one sheet.) Once the machine has tripped, before re initializing the machine, I looked at the drives, to see if there were error codes - nothing, all looked fine there.
Has anybody had something like this? I have gone through the obvious (E-Stop etc), but cant seem to find where it comes from.
Tristan Brammer
CAMaster Cobra CR-609 ATC
2018 CAMaster Elite CR-609 ATC
WINCNC
Enroute 4 and Aspire v8 Design Software
AutoCAD, Autosketch, Sketchup
Razor CNC
Aspire v8
"Sawdust means Work in Progress"
Old 11-17-2018, 09:59 PM
Did you email tech support? Obviously I have zero idea.
