Go Back   CAMheads CNC Router Forum By: CAMaster CNC > The Water Cooler > The CAMhead Locker Room! > blmac4 Bobby Mcarley
Old 01-01-2014, 02:20 PM
blmac4 blmac4 is offline
Default Simple solution, I'm sure
First off Happy New Year everyone, I hope everyone hade a safe night with all of the party goers.
I have my new machine set up, the spoil board in place but not surfaced yet, no bit big enough without taking forever.
Just wanted to do a simple test design in V-CarvePro, save it, and send it to machine to make sure I can do it and have the machine run a simulation. Spelled out my name, did cut cut profile, hit save button, chose the pp for CAMaster ATC Arcs(inch)(*.tap), clicked saved. Opened wincnc, clicked open file, picked the test .tap file, clicked simulate and got "ERROR Syntax Command or File Not Found". Tried a couple of times, same results. Then tried one of the sample files that came with program, the OPEN sign file, same results. No idea what problem is.
Not sure if this is part of the problem but I noticed that there are no tools listed in the tool library in wincnc. Do you have to build a tool library or are the tools used to do a job imported in with the saved .tap file?
Also, when you open a job file sould'nt it be displayed on the screen in wincnc? I never could get it to display and when I hit the view button, I got the same error message.
I have posted some pictures of the screens.
Thanks for any help!!
Bobby
Bobby McCarley
Louisiana
Recoil Indexing Lathe
FTC, Spindle On/Off, Laser Cross Hairs
WinCNC,V-CarvePro,3.25 HP Porter Cable Router
Old 01-01-2014, 02:44 PM
As long as you have a tool library in V-carve, you don't need to set up a tool library in WinCNC. You're problem is most likely because you used the ATC post processor to save your .tap file. It doesn't understand the 'T2' command.
Bobby...
Try this: Go to this thread: http://www.camheads.org/showthread.php?t=3973 and download the "CAMaster Single Tool IN" post processor. Owners paswd required. PM me if you need it.
Save it to your desktop. Right click on the file and select Copy, Then open VCarve Pro or Aspire, > File menu > Open Application Data Folder > Post P and paste the postP in that folder. Close VCarve Pro or Aspire, Reopen. Open your file and save the toolpath using that new postP.
Zero your bit to the surface that you designed to in the design software and try it again.
Old 01-01-2014, 03:58 PM
Another great suggestion from this forum is to move all unused post processors from the same folder so that you only have a couple to pick from when saving your tap files. Mick explains it here.
http://www.camheads.org/showthread.php?t=3182
Old 01-01-2014, 04:03 PM
Thanks Charlie, if you don't move the unused post processors into a new folder there will be a lot of post processors to sift through till you find the correct one.
Old 01-01-2014, 11:34 PM
Thanks for the replies, they were all helpfull and appreciated. After I added the new pp and used that pp for the test file it worked fine. Gary, do I need to go ahead and install the rest of the new pp files and and will they replace the old pp?
Bobby
Bobby McCarley
Louisiana
Old 01-01-2014, 11:42 PM
Bobby
According to your signature block you have a Stinger I non FTC and non recoil (lathe) you only need 1 post processor.
Old 01-02-2014, 12:21 AM
Mick,
I edited my signature line to be more detailed. Before it showed the performance package which does include the FTC option, spindle on/off and laser cross hairs and I do have the recoil indexing lathe on my unit. So I assume I would need those pp for those features when I use them.
Bobby
Bobby McCarley
Louisiana
Old 01-02-2014, 12:36 AM
Sorry I only thought you had a Stinger I non FTC, you are correct you can use an FTC or ATC you also need an X2A post processor .... DO NOT USE ONE FOR THE X3
Old 01-02-2014, 08:37 AM
Bobby...
Mick is correct, You will be able to use 4 posts. The Single tool for 3 axis and the recoil single tool for non tool change (FTC) cutting files, and the Tool Change 3 axis and Recoil versions for multiple tools for FTC use.
FYI: We are currently shipping all Stingers with the FTC disabled. This allows our new and inexperienced users to use a single tool postP, zero to the design plane and get experience with some simple cuts to gain confidence. Once they wish to begin using the FTC features, Tech Support will enable them. Luke will give you a few instructions to make sure you are up to speed and enable the tool changes. You will then be able to use either the single or toolchange posts for 3 axis or recoil cutting at your discretion.
