Go Back   CAMheads CNC Router Forum By: CAMaster CNC > New CNC Setup. > General Discussion
Old 02-03-2021, 04:39 PM
mcclusky mcclusky is offline
Default Head not switching directions.
Hello all.
I sent in a ticket through the camaster website but as I wait for a response i wondered if anyone had any info on this matter.
This is a cr-508-atc
It suddenly started messing up sheets during cutting (cutting parts in the wrong place, and fraying edges) eventually it would hit the hard limit switches and trip the servo.
After turning everything off and cleaning the machines i tried to initialize but again it's just ramming the switches and tripping servos. I did get it to initialize fully one time but after jogging the head around the table using the keyboard, i noticed that it is moving in the wrong direction (some times) like there is a problem changing direction.
This is happening with z, y, and x.
Any ideas?
Old 02-03-2021, 04:46 PM
james mcgrew james mcgrew is online now
Is it grounded ? Also I run a copper wire from my spindle to my Dust collector
Old 02-03-2021, 05:09 PM
I will check on that because I really don't know (I wasn't around for the install). I just found the static reduction thread by Gary so I'm going to dig into that and see if I can resolve anything.
Thanks!
Old 02-03-2021, 05:53 PM
Also double check all of the cables from the machine to the computer. Take them all off and reseat them. It sounds like there is some sort of interference between the control machine and the CNC. It could be static, cables, bad cards, etc. The first two are the most likely culprits.
Old 02-04-2021, 10:04 AM
Talking
I re-seated the pci card and cables and it seems to have solved it.. what a relief.
Thanks guys
I'll follow up if anything else happens
